Old 07-01-2014, 11:17 AM   #1
Coach529
Coach529's Avatar
Exhaust close to brake master cylinder
OK......finishing up my SBC conversion in my stock framed 3600.
Exhaust is about 2" from my master cylinder. Only way to space it further away is to hang it down lower, which I am not willing to do.
Is this something I should worry about?
Should I use some header wrap on it?
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 07-01-2014, 11:30 AM   #2
nvrdone
Re: Exhaust close to brake master cylinder
My exhaust is about 3" from the master cylinder. I tend to err on the side of caution and wrapped my exhaust pipe. Have had no concerns with the power brake conversion
nvrdone is offline   Reply With Quote
Old 07-01-2014, 11:31 AM   #3
69chevytrucker
69chevytrucker's Avatar
make a heat shield to deflect the heat just out of some tin and you should be fine curve the tin like half round tack it to couple worm or ring clamps and put it on exhaust pipe if you get what i meen lol
69chevytrucker is offline   Reply With Quote
Old 07-01-2014, 11:33 AM   #4
69chevytrucker
tin only needs to be just off the pipe like a 1/4 inch to deflect the heat
Old 07-01-2014, 11:33 AM   #5
Coach529
Coach529's Avatar
I am in the same boat on the opposite side.......I am about 2" from the starter.
1949 Chevy 3600
Old 07-01-2014, 03:29 PM   #6
_Ogre
_Ogre's Avatar
as suggested by 69chevytrucker, a simple heat shield will work for both applications
shop air compressor timer
