seam to be losing AIR
just fixed the air door that little plastic piece breaks on. Well I fixed it with a little piece of metal bracket and it opens and closes now. Still dont get much air through the vents after putting the all the vents back. and barely get any air through the defroster vents...... come out strong through the flor vent though
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
78K & 79C Jimmys
Re: seam to be losing AIR
sounds like somethings come loose
defrost and dash vents should be off
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Ok I got something that is messed up. I did notice that (truck running) I put it on MAX AC and the vent on the passenger kick panel opened up. I figured MAX would be all inside air..... I think the PO messed something up when the heater core was changed. I have not had it out at all
78K & 79C Jimmys
I'd check the lines are right then
yea, now I just gotta make the time for that
yes the pass vent opens up, and the one in the cowl by the pass wiper closes, so it recirculates the air.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
so its suppose to open on MAX AC ?????
yes.
78K & 79C Jimmys
No they both close.
Cowel and kick panel.
for that matter, why would the kick panel open at all with the AC ON in either position. that lets in outside AIR that is not circulated across the condenser
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe Last edited by bigd65; 07-01-2014 at 03:42 PM. |
Slots go on anything!
It pulls the cooled air across the evaporator coil (behind the dash). The kick panel vent is only open at the top. When the upper flap closes, the blower motor recirculates the inside air.
You might want to pull the ducting and reseal it. That might help out as well.
1974 Jimmy- 5.3/4L80e/NP241 |
I think I'm going to pull the whole thing. See if the all the actuators are working. Can't get much air through the defroster vents.... Might be backwards.... Knowing the previous stuff I have had to straighten out
the kick panel vent opens so the fan can pull the air from the cab back thru on max, at the same time, the cowl vent thats normally open, so you get fresh air, closes so all you get is recirculating air.
78K & 79C Jimmys
Something else,
The actuator floor/defrost has three holes. I use the middle, all up or down. But some are made to leave some up or down all the time.
#15 |
Crew cab , that makes sense.....
Motor nut , I get VERY LITTLE air through the defroster duct when on DEFROST.... I get a lot of air on the floor when on heat....
