Old 07-02-2014, 08:46 AM   #676
Coach529
Coach529's Avatar
Re: 1949 Chevy 3600 into a daily driver
Originally Posted by sqrlnts View Post
Too loud, you know what they say about that!!! Where did you exit your exhaust? If you have turn downs they can have a bit of a drone. If you have not welded your exhaust up solid you can try rotating the tips around bit. I don't know that a crossover will help quiet it down, maybe different mufflers??
I was once told your lean if you backfire through the carb and rich if you backfire throught the exhaust.
On your alternator, Terminal 1 is your field excite wire (white?) should be switched hot. Terminal 2 is remote voltage sensing, try jumping terminal 2 to the big red battery wire on the alternator stud, might also cure your run on.
Here is some better info on the 3 wire, about half way down the page.
The exhaust exits through turn downs right in front the of the rear dif.
Thanks.......I will look into the alternator wiring before I buy new.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 07-02-2014, 02:46 PM   #677
sqrlnts
No problem. I am running a dual exhaust dumped in front of the axle as well. Originally my dumps turned straight down into the ground. I found that if I rotated them outward they were a bit quieter.
It also acts to blow burnout tire smoke much greater distances.....
sqrlnts is offline   Reply With Quote
Old 07-02-2014, 03:22 PM   #678
dubie
dubie's Avatar
I think we need some video proof of such claims
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 07-02-2014, 08:40 PM   #679
Coach529
Coach529's Avatar
Well, today I was working through my punch list of stuff while waiting for the UPS man to deliver my driveshaft.
I got the alternator to charge which was awesome.
Next step was to investigate the starter and why it was occasionally making noise.
Digging in a little deeper....it appears I have made an error when I installed the flex plate.
View looking towards the transmission.
I am now trying to figure out if I can get enough room between the tranny and motor without pulling the motor. Hmmmm.
Any advice??
........and the damn driveshaft never showed up.......
1949 Chevy 3600
Old 07-08-2014, 10:43 PM   #680
Coach529
Coach529's Avatar
OK, so I pulled the tranny back and R & R the flexplate in the correct orientation. I bolted the tranny back up and have about 3/8" of space between the flex plate and the bolt pads for the converter. Is it OK to slide the converter back out to the flex plate and bolt up?
1949 Chevy 3600
Old 07-08-2014, 11:02 PM   #681
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
My tranny guy told me that 1/4" is okay. Anything more than that, add a washer to take up some of the gap. You don't want to pull the converter any more than 1/4" out of the pump.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-10-2014, 11:48 PM   #682
Coach529
Coach529's Avatar
Another huge hurdle has been crossed!! Henry is BACK on the road.
I finished buttoning up the torque converter and flex plate issue and bolted on the brand new driveshaft. I double and triple checked everything and dropped him down on all 4 wheels.
Fired right up and I checked the tranny fluid. After adding some I backed him out of the garage!! Huge smiles!!!
A couple spins around the neighborhood and more checking of nuts and bolts and I advanced the timing to get rid of a pesky miss right off idle. By the end of the night I had it running really good......I am hitting up my local repair shop tomorrow and check the timing and take a look at the carb. They specialize in hot rods and race cars.
Still not 100% sold on the exhaust.......It is a little loud and I get a resonation at certain RPM's that will drive me nuts. Hoping some dynamat on the floor will help.....other wise new mufflers.
1949 Chevy 3600
Old 07-11-2014, 12:43 AM   #683
sqrlnts
Congrats man nothing like playing around with a small block. IMHO dynamat will help some but the drone will stay as long as your running dumped exhaust in front of the axle on these old metal cans.
If you can, run some additional tubing out of the mufflers and not pointed at the ground, fire it up and do some un-scientific revving research.
Old 07-11-2014, 10:16 AM   #684
Coach529
Coach529's Avatar
We timed this thing originally with just the open headers. Now that I have added the full exhaust system, the timing is pretty far off.
I am just timing by ear, but I have advanced the timing quite a bit, and still do not have any pinging under load. The more I advance the timing, the better it idles and the quieter it is.
Just got back from a drive and am pretty damn happy with the noise level.
1949 Chevy 3600
Old 07-11-2014, 10:32 AM   #685
Tx Firefighter
Remind us again what mufflers and exhaust size you chose. I looked back a few pages and didn't see it.
Old 07-11-2014, 10:36 AM   #686
99 to Life
99 to Life's Avatar
congrats, let the fine tuning begin!!!! What I'd do is get yourself a vacuum gauge, hook it up to the manifold or if your carb has another port go there. It will be your best friend. Play with the timing until you get the most vacuum and set it there, try it out, bet you'll love it. Also warm up the engine bf you tune the carb.
as for exhaust I run true duals that dump bf the axles with tips pointing down. I run flowmaster 50s and I have no problems, if anything I want more sound sometimes!!!! but really it does have a nice idle, you can talk in the cab etc. I run padding under my carpet and have put sound barrier where I could. The wind and any gaps in doors or windows will create the most noise. I even put foam padding in my doors.
good luck and have fun, glad your back on the road.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 07-11-2014, 10:38 AM   #687
Coach529
Coach529's Avatar
I went against my original thoughts. Before this whole driveshaft debacle, I was running out of time so I bought some mufflers and pipe local. As it turned out, I ended up waiting for the driveshaft....so I could have waited for the Brockman's.
At the advice of my local shop guy, whom I trust, I bought some mufflers and 2-1/4" pipe. The mufflers are similar to a Thrush Turbo sounding.
1949 Chevy 3600
Old 07-11-2014, 12:08 PM   #688
NEWFISHER
NEWFISHER's Avatar
Awesome! A cross over pipe should nock the sharpness and drone from the system. Those muffler look SHORT and may be your issue.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 07-11-2014, 12:49 PM   #689
Coach529
Coach529's Avatar
The bodies are 18" long, so maybe. I am not making any decisions until I get the floor back in the truck and get it fine tuned. It is almost acceptable right now in town.......
1949 Chevy 3600
Old 07-13-2014, 11:04 PM   #690
Coach529
Coach529's Avatar
Solid weekend in the garage.....despite other responsibilities!!
Swapped out my junkyard alternator for a new rebuilt......now we are charging.
Chased down a noisy vacuum leak.
Bolted on the hood and front bumper.....looks much better.
Every errand this weekend ended up being a mini cruise session.......took the LONG route everywhere!! :-)
I think my battery is junk......I cannot get it to take more than 12VDC even after sitting for 12hours on a trickle charger......last winter was tough on it.
Motor pulls good off the bottom, but needs some tuning in the midrange. Should pull harder I think. Really please overall though. Runs awesome......so happy!!
Ended the weekend with a long cruise with my oldest and youngest......good times!!
1949 Chevy 3600
Old 07-13-2014, 11:46 PM   #691
99 to Life
99 to Life's Avatar
sssaaaaaawwweeettt. I'v lately made a pact to drive my 51' friday-monday when I'm with the truck, rain or shine. Its a great feeling. Getting so caught up in other builds and life its easy to back burner the rig.
congrats man, that tuning part is a catch 22. real fun figuring out your engine and what it wants, not fun not getting it right. I'd get a vacuum gauge man, really will tell you the most. Make sure your balancer is true TDC with your tab. Run piston up till it stops, mark your balancer, run it other way till it stops, mark balancer, split the two marks and thats your true TDC on your balancer.
don't always assume marks are right till you check. Play with the timing a little and if you know your cam specs that will help out.
Tune carb when your warmed up.
Old 07-14-2014, 12:25 AM   #692
whitels1
whitels1's Avatar
On my K10 project I'm going to try your CLR / carnuba wax and see how it works out. I love the look of your truck.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 07-18-2014, 07:27 AM   #693
Coach529
Coach529's Avatar
Still tinkering and cruising daily.
Spent some time at the local repair shop. My timing was right on, but I had the vacuum line to my HEI on the wrong port on my carb, so I had no vacuum advance except at high rpm. That woke it up.......runs like a scalded cat now!!
1949 Chevy 3600
Old 07-18-2014, 01:35 PM   #694
nvrdone
Glad to hear yours runs like a scalded cat. The sbc sure makes a difference. After 30 years with mine, I still have fun smoking the ricers
nvrdone is offline   Reply With Quote
Old 07-18-2014, 09:38 PM   #695
99 to Life
99 to Life's Avatar
nice man, little tuning that turns out for the better is great. Not sure if you run a carb spacer, but I find the 1" phenolic spacer helps out alot with heatsoak and to keep the fuel a little cooler, esp with an aluminum intake. I also insulate all my fuel line in the engine bay.
If you know what cam you have, you can really dial in the timing. at anyrate, pop and plug your vac advance rev it up to 3-3500 rpm and see where your
marks are at, if you have a timing tape. Really helps to know you all in timing
vs just setting it at initial timing. if your guy hasn't done that already. if you don't have timing tape you can use a preset style timing gun.
Old 07-23-2014, 04:53 PM   #696
Coach529
Coach529's Avatar
1949 Chevy 3600
Old 07-23-2014, 09:04 PM   #697
NEWFISHER
NEWFISHER's Avatar
Mike, what are you doing for mirror heads?
GOD BLESS AMERICA!
Old 07-23-2014, 11:08 PM   #698
Coach529
Coach529's Avatar
I need to hit the junkyard and find a head that is properly aged and get a mirror cut.
1949 Chevy 3600
Old 07-24-2014, 10:50 AM   #699
NEWFISHER
NEWFISHER's Avatar
I have some new rectangular ones if you cant find what you are looking for. Maybe set them out behind the new shop and pee on them for a month?
GOD BLESS AMERICA!
Old 07-24-2014, 11:32 AM   #700
Coach529
Coach529's Avatar
I am actually hoping to find some small rounds ones.
1949 Chevy 3600
