![]() Join Date: Mar 2014
Help! Auto Shifter
66 C10 with 700R4 Auto. I am looking for a column shift solution. Have no idea what to use to connect the 700R4 to the original automatic linkage? I have an original rod from the column but that's it, Is there another year truck out there that has the linkage I need or do I go aftermarket...if so what have you used with success?
Re: Help! Auto Shifter
I was told that the original linkage would. I saw it done on th350 to 700r4 swap and all it took was a little tweak of the rod
