Old 07-02-2014, 12:52 PM   #1
Orange72ChevyC10
Orange72ChevyC10's Avatar
Help me identify these things....
In the first two attachments I cannot determine what this plug is for...it is "T'd" off the brake booster vacuum but there is nothing connected to the plug.
Orange72ChevyC10 is offline   Reply With Quote
Old 07-02-2014, 12:54 PM   #2
Orange72ChevyC10
Re: Help me identify these things....
In these two pictures there appears to be a vacuum hose from the firewall that is suppose to be plugged into the round device (not sure what the device is) that no longer reaches...thoughts?
Old 07-02-2014, 12:55 PM   #3
Orange72ChevyC10
On top of the Vapor Canister the cap appears to have once had a 3rd plug, is this true? Is it necessary?
Old 07-02-2014, 12:57 PM   #4
Orange72ChevyC10
Sorry for the massive request however I am trying to confirm I do not have a vacuum leak that might be causing a weak/lack of idling.
Thanks in advance for any insight.
Jason
Old 07-02-2014, 01:04 PM   #5
csfields
csfields's Avatar
The vacumm hose coming out of the fire wall. There should be three total. One goes to the washer jug and the other two go to the sprayers under the windshield. All three run into the cab to the washer motor / pump.
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline   Reply With Quote
Old 07-02-2014, 01:17 PM   #6
Bigdav160
Bigdav160's Avatar
Those hoses are shown in the 2nd picture.
The other hoses are on the passenger side and they are for the heating - A/C
One goes to the vacuum reservoir (that block ball) the other to the heater control valve and the other to the fresh vacuum motor (I think)
The small black thing is a vacuum check valve. And the other is some type of vacuum solenoid. I'm not familiar with them as they could be part of the TSC emission thing on '72 models or part of the broken purge valve on your charcoal canister. I'm not sure . That stuff was removed from my truck.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-02-2014, 07:01 PM   #7
68Gold/white
Pic. 1 vacuum check valve.
Pic. 2 vacuum solenoid found starting on early 80's GM vehicles w/ lockup torque converters.
Does your trans have any electrical wires on drivers side connecting just above pan???
Pic. 3 I'm thinking hose does possible hook up to pic 4 (which is a vacuum reservoir, needed for heater control stuff). My 68 washer hoses come out of dash on drivers side through a round grommet, w/ 3 holes in it...if I remember...
Pic 5 Do you need to have vapor canister functional, where you live??? If not, plug off sources that connected to that vapor canister. I don't know if a 3rd hoe is needed on vapor canister, I've seen some that look like yours, looks like a B-B was shoved in hole...
If your are chasing a vacuum leak, plug ALL the hoses that are connected to the engine, see if that helps. If it does, you can reconnect them one at a time to find out the leak.
You rubber hoses look like they need some TLC, you'll get it done!!!
68Gold/white is offline   Reply With Quote
Old 07-02-2014, 07:53 PM   #8
larley
To find a vacuum leak I like to spray a little starter fluid at potential spots, you will hear the difference. Works for me.
larley is offline   Reply With Quote
