Old 01-11-2004, 01:10 PM   #1
griesel72
griesel72's Avatar
any wiring experts here?
I bought a new wiring harness (engine) and need some help figuring out where everything goes. It is the harness that runs over the firewall lip, and (i think) hooks up the the starter, dist and other.
the two wires that attach to the starter are yellow and purple, which post on the starter do i attach them to?
Also, there is a brown wire with a boot with a circular connection, a blue wire with a boot with a female spade connector and a green wire with a square female connection.
Thanks for any help
David
I tried to look at my 69 to see where everything goes, but i didn't want to clean off 2" of oil/dirt/grease
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 01-11-2004, 01:21 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Brown should be on the drivers side....master cylinder.
Blue...no idea. Do you have A/C? (this wire was mentioned a few weeks ago, but I can't remember what it is...maybe the Amp guage...as there an inline fuse on it?)
Purple goes to the 'S' terminal on the starter.
Yellow goes to the 'R' terminal. However, if you have HEI, then you need to delete this wire.
Old 01-11-2004, 01:21 PM   #3
jef5150
Inline 69
jef5150's Avatar
http://www.geocities.com/chevroletc1070/wiringdias.html
jef5150 is offline   Reply With Quote
Old 01-11-2004, 01:37 PM   #4
cdowns
cdowns's Avatar
green water temp
blue oil pressure for idiot light dash
Old 01-11-2004, 01:40 PM   #5
griesel72
griesel72's Avatar
So i need to get rid of the yellow wire? Do i just not hook it up, or cut it off (since i have hei)
Where do i hook up the wire for the amp gauge?
To convert for hei, is all i have to do is to run a wire from the ign port on my fuse block to the distributor cap?
Thanks for the help
David
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
Old 01-11-2004, 01:51 PM   #6
griesel72
griesel72's Avatar
Also, is the R terminal towards the block, or towards the outside to the starter?
David
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
Old 01-11-2004, 02:12 PM   #7
cdowns
cdowns's Avatar
R is closest to the block ,just get rid of the yellow , yes run the new wire from fuse to distrib
Old 01-11-2004, 02:16 PM   #8
griesel72
griesel72's Avatar
Thanks Longhorn Man, Cdowns and jef5150, i think i have it figured out now
David
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
