#1 | |
Still Learning
Re: Project Beatrix
Re: Project Beatrix
You have a Beautiful truck started there. I really like the grey powder coating on the frame. I have been looking at the same for mine...what grey did you use?
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
Re: Project Beatrix
^^^What he said^^^
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
Re: Project Beatrix
Trash Truck 69 GMC |
Re: Project Beatrix
Man this thing is coming along. Lookin awesome, man.
Todd https://www.instagram.com/shores6/ Project: Boosted Blucille. '70 C10 SWB PB Fab, LS2 S480 - http://67-72chevytrucks.com/vboard/s...d.php?t=700419 |
#6 | |
Re: Project Beatrix
They are coming slowly but surely! ![]() Thanks shores ![]()
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
Re: Project Beatrix
I feel like you probably read up a lot on your set up and I have a LQ4/4L80e questions!!!! Can you run that set up with a ls1 style intake without changing the truck harness to the f body engine harness? and if you do have to change to the f body harness... do the transmissions (4l80e and 4l60e) share the same connections?! I know f body guys get 4l80's built and use them with the factory PCM... Hopefully I'm making sense. If you can shed a little light on the subject or have a link to something, thank you. If not... thanks for building a badass truck and documenting it.
#8 | |
Re: Project Beatrix
#9 | |
Re: Project Beatrix
A friend tried to steer me away from the 4l80 saying it was "more work than what its worth" and said to just built the th400.
Re: Project Beatrix
Brandon - great looking pickup so far! I'm loving the frame and engine colors. Sorry if you provided already, but can you let us know what tire sizes you are running?
Thanks! |
Re: Project Beatrix
Jerimy I am running 265/35R22 up front and 285/35R22 in the rear.
Re: Project Beatrix
Re: Project Beatrix
Finally got the mount built for my Accuair Exo mount. Wanted to keep everything together and out of the way so I designed a mount to hold the whole unit and float it over the gas tank. Think it turned out pretty good for a simple design that bolts to the notch with rivnuts!
#14 | |
Still Learning
Re: Project Beatrix
#15 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Re: Project Beatrix
Looking good man!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#16 |
Re: Project Beatrix
Thanks fellas! ![]()
#17 |
![]() Join Date: Dec 2012
Re: Project Beatrix
Brandon, that is awesome!!
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
#18 |
Re: Project Beatrix
That looks great!
#19 |
Re: Project Beatrix
Thanks guys, hopefully I will get my elevel sensors mounted up tonight and start plumbing the airlines. Once that is done I can get the bed floor frame figured out.
#20 |
![]() Join Date: Dec 2006
Re: Project Beatrix
Nice job on the accuair bracket Brandon
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#21 |
![]() Join Date: Feb 2010
Re: Project Beatrix
That looks familiar. I like it. Are you doing hardlines?
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417 |
#22 |
Re: Project Beatrix
Thanks guys!
Woodnears I guess great minds think alike ![]()
#23 |
Re: Project Beatrix
I full agree, I plan on having a few extra feet of tubing and a splice or two in the truck at all times.
#24 |
Re: Project Beatrix
That mount looks awesome man!
#25 |
Re: Project Beatrix
Thanks Todd, took a few attempts to get it right but I am happy with the result.
Got the front end sand blasted and in epoxy primer. Going to start getting on the metal work and hopefully get the bed and doors off to the blaster this week. ![]() ![]() Front end is just set on the frame to keep the stuff out of my way for now, which is why the cowl and hood look funky. Still got my fingers crossed with this Holley Hi-Rise fitting under the stock hood. If it does, it will be really really close.
