Old 07-05-2014, 12:20 PM   #1
Kenfuzed
Kenfuzed's Avatar
Parking brake components
I recently bought a 66 C10 SWB that I'm in the process of putting back together. The PO appears to have remove almost all of the parking brake parts. All that remains is the 2 rear cables hanging out of the drums (zip-tied to the frame) and the lever under the dash. I don't see any remaining brackets or hardware so I'm starting from scratch.
Does anyone have a list of all the parts I need and if any vendor sells all of them still? A parts manual is next on my list but I was hoping to get an accurate list so I can just buy everything I need all at once.
Current truck specs: 1966 C10 fleetside shortbed, th350 auto, 6 lug rear drums. Unknown what is original and what is borrowed since the front clip suspected to be from a mid-70's truck (5-lug disc) and the trans cross member looks to be changed (different shade of dirt).
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 07-05-2014, 02:16 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Parking brake components
Here is a detailed pic of pieces.
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=97
But compare the prices from other vendors.
LMC tends to be overpriced on many things.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-05-2014, 06:07 PM   #3
bmacneal
be careful, the brake cables for a coil spring axle are different than a leaf spring axle. there is a company named " inline tube" that makes reproduction cables for both leaf and coil spring axles. www.inlinetube.com give them a ring. very nice people. they sell most of their cables on ebay. they also make pre-bent brake lines if you need them
bmacneal is offline   Reply With Quote
Old 07-05-2014, 06:20 PM   #4
jayoldschool
Moderator
Too funny. My truck has all the parts except for the parts you actually have...
jayoldschool is offline   Reply With Quote
Old 07-05-2014, 07:25 PM   #5
Kenfuzed
Kenfuzed's Avatar
Thanks this is what I was looking for! The previous owner did all new brake lines but left off the e-brake parts.
Enjoying the ride!
