07-05-2014, 11:17 PM | #1 |
Transmission lines 4l60e to stock radiator
I'm trying to figure out what to do on the transmission cooler lines to the radiator. I was hoping to use the factory 2003 lines for my 5.3/4l60e, but the front frame crossmember is in the way. I know i can run AN lines, but looking to see what else is out there.
72 Suburban using stock 72 radiator and 4l60e trans. |
07-06-2014, 01:37 AM | #2 |
Re: Transmission lines 4l60e to stock radiator
if I were to do it again, I'd run stock lines as far forward as possible and then use AN fittings. soft line all the way up not very awesome
07-06-2014, 01:51 AM | #3 |
meowMEOWmeowMEOW
I ran braided line from trans to cooler all the way, and it was plenty easy, especially with where mine passes by the exhaust.
You can also use the stock "Stub" on the trans, then use unions and hard brakeline to bend a path to the cooler, if you don't want any braided line. OR, you can combine both ideas...running stock stubs and hard line, then adapting to braided for the end run.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
07-06-2014, 05:47 PM | #4 |
I used 4l80e lines my buddy had laying around his shop in my 74. Had to do a lil bending and cutting but they work fine.
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
07-07-2014, 02:24 AM | #5 |
meowMEOWmeowMEOW
the trans-end of the stock lines is different on the 4l60e, the 80e has that "Stub" that goes into the case when you plug the quick connects in. Did that fit your 60e?
07-07-2014, 02:48 AM | #6 |
If i remember correctly the transmission end of the line went right in...the radiator end was modified to fit my radiator. Ill try n post some pics later...have to work on it today
07-07-2014, 01:28 PM | #7 |
Bend your own. It's pretty starightforward.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
