Old 07-06-2014, 10:26 AM   #1
RickyPatty
In need of engine decoder help!
I have a 66 c10 and I've decoded the VIN already,but I am having a hard time finding out if it is a 230 or a 250. I have read that the 250 came in that year but a few signs point to the 230.
RickyPatty is offline   Reply With Quote
Old 07-06-2014, 07:40 PM   #2
66Submarine
66Submarine's Avatar
Re: In need of engine decoder help!
Not familiar with that number. Can you post some more pictures of the rest of the engine, including the other casting numbers?
Welcome to the forum, BTW.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 07-06-2014, 08:54 PM   #3
Lowl!f3
Lowl!f3's Avatar
also further away pic for location of distributor please.
only one I find even close is 3877178 and thats a 230 or 250.
However it doesnt look like in your pic that the 3 was ground off the serial.
1965 C10 Project
Lowl!f3 is offline   Reply With Quote
Old 07-07-2014, 12:43 AM   #4
RickyPatty
That was the issue I was running in to. Here are some more pics, hopefully they help.
Old 07-07-2014, 12:47 AM   #5
RickyPatty
Another pic.
Old 07-07-2014, 01:00 AM   #6
66Submarine
The date code has 6 for the year, so it's a '66 or '76. Given that the truck is a '66, I'd guess it's probably the 250 that came in there. AFAIK all trucks '66 and later had the 250.
A way to tell would be to see if you can determine if the pistons are dished or not; a 250 has dished pistons and 230's have flat top pistons.
Old 07-07-2014, 01:01 AM   #7
66Submarine
What is it that makes you think it's a 230, anyway?
Old 07-07-2014, 08:11 AM   #8
RickyPatty
When I first started searching for this I found a forum that said if it is a two pulley system it's a 230. Another reason is that it is a base model so If the 230 was available I figured it was that.
Old 07-07-2014, 10:42 AM   #9
66Submarine
Not sure what that guy was smoking! Lots of misinformation out there. Anyway, it should be a 250 unless it's been swapped out for a car engine (AFAIK you couldn't get a 250 in a truck in '66, and it would be a special order item if you even could).
Old 07-07-2014, 10:47 AM   #10
RickyPatty
So I'm going to say it is a 250 then. Thank you for the help, I'm still new to this and I'm trying to make sure everything's perfect before it goes in storage.
Old 07-07-2014, 03:26 PM   #11
60-66
60-66's Avatar
To do this right, look just to the left of the distributor on the machined surface. Clean it off and tell me all the numbers and letters that are stamped there. This will positively ID what it is
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 07-07-2014, 03:36 PM   #12
66Submarine
Do you have a list of the engine codes for inline sixes? I've looked and can't find anything online.
Old 07-07-2014, 04:46 PM   #13
60-66
60-66's Avatar
Yes, I have all the books to cover trucks.
Old 07-07-2014, 06:14 PM   #14
RANDY COX
RANDY COX's Avatar
If you don't mind look at mine also.. I know what the first few mean but not the last 2 letters. F0303UH
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 07-07-2014, 08:09 PM   #15
66Submarine
Neat. I'll have to send you a couple #'s when I get them down.
Any chance you'd want to scan them (or take some pictures or something) for the greater good when you get the chance? AFAIK there aren't really any lists of the I-6 numbers available online now.
Old 07-07-2014, 11:25 PM   #16
60-66
60-66's Avatar
Hi Randy ! The UH suffix was used from 1965-1969 on 292s . If you give me the casting date, I can tell you the day and month AND year your engine was assembled . Your F0303UH . The F is for Flint, the first 03 is the month, the second 03 is the day. So third month=March 03 or March third day of ?year? The year would be determined by the casting date. Hope this helps. Jon
Old 07-08-2014, 06:31 AM   #17
RANDY COX
RANDY COX's Avatar
Ok Thanks. I have 2 292's and one has the bigger plug and the other has smaller plugs. Yea I wasn't sure what the UH meant if anything.
1964 BBC 402 4x4
Old 07-08-2014, 08:11 AM   #18
60-66
60-66's Avatar
UH basically means its a 292 with manual trans. Some codes are more specific. . Your small plug 292, whats the code on that ?
Old 07-08-2014, 10:44 AM   #19
RickyPatty
Alright I cleaned off the plate and hopefully this issue can be resolved. I have CON2 E36
Old 07-08-2014, 11:15 AM   #20
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: In need of engine decoder help!
http://67-72chevytrucks.com/vboard/s...d.php?t=382583
http://67-72chevytrucks.com/vboard/s...d.php?t=356268
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 07-08-2014, 11:32 AM   #21
60-66
60-66's Avatar
Those numbers are "CASTING" numbers, I need the "STAMPED" numbers right next to the distributor in this location.
Old 07-08-2014, 12:22 PM   #22
RickyPatty
Alright I got it this time the STAMPED number is F0506TA
Old 07-08-2014, 12:58 PM   #23
60-66
60-66's Avatar
Perfect ! TA suffix is used for 1965 for a 230 six and 1966-1968 on 250 six with manual trans in truck only with that suffix. Now if you can find the casting date we can tell what year. It will read like H 6 5 or A 12 6 just as examples and be about 1/8 to 3/16 tall CASTING letters and numbers . More than likely a 250 if its the original engine to your 1966 truck. Strange how they repeated the TA suffix for both 230 and 250, that's not to common. There wasn't a 250 till 1966.
Old 07-08-2014, 01:12 PM   #24
66Submarine
He said it was E 3 6, so that confirms it as a '66 250.
Old 07-08-2014, 01:51 PM   #25
60-66
60-66's Avatar
Ok, didn't read that. It falls perfect then. 1966 250. Find the thread of yelmers and he can tell you what month this body 1966 was built. He started a list of all the 66s we have on here.
