Old 07-09-2014, 08:12 AM   #2126
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Originally Posted by Dieselwrencher View Post
It looks great! Isn't it funny how bad new paint makes all your old parts look? I had finding good rear sliders and settled on the one I have for now. Good luck with it!
Thanks Ryan, Yep that new paint makes my old parts look mediocre to say the least. I'm way past the point of thinking this truck is going to be more than a nice "driver". I really like reusing 40+ old parts anyway. I will drive this one and love it.
Originally Posted by jeh View Post
Everything is looking good Mike, the trim looks great with the red paint.
Thanks Jason.
Originally Posted by mjensen View Post
Excellent! The truck looks soooo good!!!
Thanks Mike
Originally Posted by Zoomin View Post
Won't be long before you are slinging the clubs in the back and heading for the course. Looks great Mike.
Thanks Steve. I'm ready to get a break for sure. You about ready to take me to your local course
Originally Posted by swamp rat View Post
X2! Real sweet!
Thanks.
Old 07-09-2014, 09:18 AM   #2127
Low Elco
Re: 1969 Short Wide
Looks great Mike!
Low Elco is offline   Reply With Quote
Old 07-09-2014, 11:02 AM   #2128
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Originally Posted by Low Elco View Post
Looks great Mike!
Thanks Chip.
Old 07-09-2014, 12:01 PM   #2129
jlsanborn
jlsanborn's Avatar
Re: 1969 Short Wide
Awesome work Mike!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 07-16-2014, 01:53 PM   #2130
shearjs
shearjs's Avatar
Re: 1969 Short Wide
Mike,
Did you have any trouble evacuating and charging your a/c system? I've rented a vacuum pump and the gauges from the local Auto Zone, and plan on tackling this myself. Any tips or hints you can give to an a/c rookie?
shearjs is offline   Reply With Quote
Old 07-16-2014, 02:16 PM   #2131
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Originally Posted by jlsanborn View Post
Awesome work Mike!
Thanks!
Originally Posted by shearjs View Post
Mike,
Jason,
I didn't have any trouble evacuating or charging my system. I did however overcharge mine and it caused me a day or two of frustration. What I learned is that the Vintage Air system I have ( sure fit early model cable driven) only requires 1.8 lb. of Freon. I had installed two cans plus what I thought was about a 1/2 can. It made my compressor cycle frequently because I was over pressure on the high side. Check THIS out . I would start with 2 cans and go from there.
I'm not an expert by any stretch but this is how I always do my evacuations.
1.) purge the system with dry Nitrogen (150-200PSI). If you don't have nitrogen, I suppose you could use filtered compressed air. but this will add moisture to your system. Moisture
is no good for a/c system. But there is no need to dump gas in it if you have an obvious leak, so pressure check is kind of mandatory in my eyes.
2.) check all fittings for leaks and see that the gauge stays at pressure
3.) Gently drain the nitrogen out to 10 psi or so then connect vacuum
pump.
4.) I like to evacuate mine at least 4 hour or longer if possible. Vintage air recommends like 45 minutes min.
I borrow a manometer HERE from work that reads vacuum pressure down to .000 PSI. This isn't necessary but since I have access I use it. You can use your gauges to do the same thing it's just hard to tell if there is a small rise in pressure. If it doesn't hold vacuum it will more than likely leak. It might be small but over time the gas will leak out.
5.) charge with Freon. They recommend not flipping your cans or shaking them like we did in the old days with R-12. This can cause spike in compressor and damage it. Just be aware it will take a while longer to empty the can.
6.) enjoy cold air
Old 07-19-2014, 07:48 AM   #2132
Dean'smeanmachine
Dean'smeanmachine's Avatar
Re: 1969 Short Wide
its really coming together now
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline   Reply With Quote
Old 07-20-2014, 10:14 AM   #2133
Low Elco
Re: 1969 Short Wide
Thanks for the writeup, Mike. I's eskeert a them big hosey thangs under that thar hood.
Old 07-21-2014, 08:22 AM   #2134
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Dean. New pics soon
No problem. If I can help you any with your fittings let me know.
You have a great way with words Chip
Old 07-21-2014, 08:26 AM   #2135
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Got the interior pretty much done, still need to finish some minor things but over all I'm pretty happy with it.
Got the radio installed in the console. (Thanks Crash_OK) for donating it to the project. !
Starting to actually look like a truck again:
Old 07-21-2014, 10:51 AM   #2136
jlsanborn
jlsanborn's Avatar
Re: 1969 Short Wide
Slick install on the tunes Mike! You're patience and attention to detail really show across the whole truck.
Old 07-21-2014, 11:00 AM   #2137
jeh
jeh's Avatar
Re: 1969 Short Wide
Like the radio, that baby is looking slick Mike
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 07-21-2014, 11:07 AM   #2138
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks for compliment. I sometimes wonder if all the time I put into this truck is worth it.....I think once I'm driving it, the time will be forgotten. It's a darn good thing I don't keep track of my hours.
Thanks Jason, just trying to catch up with you.
Old 07-21-2014, 11:13 AM   #2139
knomadd
knomadd's Avatar
Re: 1969 Short Wide
Looking pretty good Mike! Keep it up, you're getting so close.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 07-21-2014, 11:53 AM   #2140
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Duane, hope to drive this puppy soon.
Old 07-21-2014, 03:26 PM   #2141
garykirby25
garykirby25's Avatar
Re: 1969 Short Wide
Looks great, won't be long!!!
My 1970 C10 Build "Project Teacher"
garykirby25 is offline   Reply With Quote
Old 07-21-2014, 04:00 PM   #2142
FL71C10
Re: 1969 Short Wide
Lookin Good! Time to get that bed out of your avatar and onto the truck.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 07-21-2014, 04:05 PM   #2143
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Gary
Thanks. I hear you. I'm ready to get this thing assembled.
Old 07-21-2014, 04:15 PM   #2144
Bennett68C10
Bennett68C10's Avatar
Re: 1969 Short Wide
Truck looks great Mike, nice job on the interior and radio install too. You will be driving in no time
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 07-21-2014, 05:07 PM   #2145
mx289
mx289's Avatar
Re: 1969 Short Wide
X2.
Truck looks great Mike.
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 07-21-2014, 07:15 PM   #2146
joey8383
joey8383's Avatar
Re: 1969 Short Wide
My favorite build. Looks incredible. What is left on the hit list before it's on the road?
joey8383 is offline   Reply With Quote
Old 07-21-2014, 10:07 PM   #2147
jeh
jeh's Avatar
Re: 1969 Short Wide
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 07-21-2014, 11:12 PM   #2148
East Tex
Re: 1969 Short Wide
Wow, lookin good!
My 1972 K5 6.0 LTR 4L60 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=622068
East Tex is offline   Reply With Quote
Old 07-22-2014, 01:16 AM   #2149
BossHogg69
motor exploder
BossHogg69's Avatar
Re: 1969 Short Wide
Everything looks so awesome! The red paint, the trim, all the details, and the grill look great. Top notch in every way, you're gonna have one bada$$ 'daily driver'!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 07-22-2014, 08:02 AM   #2150
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Keith
Originally Posted by mx289 View Post
X2.
Thanks Tom
Thanks Joey. Next on the list. Cowl panel, hood, install door seals, Tires, bed install, bed trim install....burnout
soon
Originally Posted by East Tex View Post
Wow, lookin good!
Thanks Tex.
Thanks Adam. I appreciate the compliments.
