Old 07-05-2014, 02:48 PM   #701
Xeen
Xeen's Avatar
Re: 1968 Chevrolet SWB Stepside Restomod
Hey all;
The adapter for the high pressure side of the power steering came in today and worked as advertised so the power steering is now hooked up.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 07-05-2014, 03:23 PM   #702
Xeen
Xeen's Avatar
Hey all;
Ok so I'm making progress but I don't want to get too excited because I have a ways to go yet to reach daylight.
At this point I want to hear the engine run so here is the shortlist.
1) Buy a battery.
2) Wire ignition switch.
3) Re-work fuel line from filter to rail.
4) Hook up temporary oil pressure, coolant temp and alternator voltage gauges.
5) Change out the spark plugs.
I am probably forgetting something but I will take care of what ever comes up as needed.
Old 07-08-2014, 06:33 PM   #703
Xeen
Xeen's Avatar
I purchased an Optima red top 800 CCA battery today, that should get the job done.
Old 07-09-2014, 08:19 AM   #704
Xeen
Xeen's Avatar
Hey all;
I got up early this morning and reworked the fuel line.
After that was done I headed down to the auto parts store and purchased some NGK Iridium IX spark plugs.
Old 07-09-2014, 11:15 AM   #705
Xeen
Xeen's Avatar
Hey all;
Spark plugs installed.
Next on the list is to wire the ignition switch.
Old 07-09-2014, 09:36 PM   #706
Xeen
Xeen's Avatar
Hey all:
Today when I went to install the spark plug wires on the passenger side I noticed the boot was touching the header which wont do because they will get way too hot and possibly melt so I purchased a Taylor Cable 92046 spark plug wire set because they have 135 degree angled boots to accommodate the Doug Thorley headers.
Old 07-10-2014, 09:12 PM   #707
gdavis
gdavis's Avatar
Glad to hear someone's truck is working their way. Having trouble with the wind shield.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 07-11-2014, 12:49 AM   #708
Xeen
Xeen's Avatar
You will get it George, just call around until you find someone who has experience with gasket windshields.
Old 07-11-2014, 12:51 AM   #709
gdavis
gdavis's Avatar
I did. found (find) a company that most of his work is on classic and he is cheaper than the first guy.
Check out Patches
Old 07-15-2014, 06:32 PM   #710
Xeen
Xeen's Avatar
Hey all;
I am in a partial planning stage of the wiring harness and for this go around I'm working on the neutral safety switch wiring.
I didn't know if I had the Neutral safety sub harness because the main harness was hacked to bits, after digging it all out I found the sub harness intact still connected to the trunk right where it should be.
With the original neutral safety sub harness found I can integrate it into the new harness.
Old 07-16-2014, 05:22 PM   #711
Xeen
Xeen's Avatar
Hey all;
The spark plug wire set came in today and I got them installed.
All that's left to do is to hook up the ignition switch and I'm in business.
Old 07-16-2014, 06:40 PM   #712
gdavis
gdavis's Avatar
Originally Posted by Xeen View Post
Hey all;
Hey Bryan:
I got in touch with Vic and he said that the Edlebrook electric choke carb. comes with it's own choke system. All I need is single wire coming from the ignition switch (hot) and it will work. the carb has two wires, one - and one + so my problem is solved. One will be a ground coming from the frame or motor anywhere. For I will be using a eldebrock carb. I think the number is #1402. So when do you think you will be able to start the engine?
It looks like yours will start before mine. but who is racing anyway.
Check out Patches
Old 07-16-2014, 09:59 PM   #713
SeTx67
SeTx67's Avatar
You've been busy. Get that ignition wired and a video up so we can hear that thing run
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435
SeTx67 is offline   Reply With Quote
Old 07-20-2014, 02:31 PM   #714
Xeen
Xeen's Avatar
I'm on hold for a bit I need to save up a little bit of cash.
I gotta buy a windshield and have it installed.
I also gotta go down to the muffler shop to have stainless steel exhaust installed.
As soon as that's done I will post up a video.
Old 07-20-2014, 04:22 PM   #715
Low Elco
Good progress!
Low Elco is offline   Reply With Quote
Old 07-23-2014, 01:02 AM   #716
gdavis
gdavis's Avatar
I see you posted a note to a guy about the weep holes on the back up lights. Good thought on that. You helped me with mine. I now got them right and looking good. thanks george
Check out Patches
Old 07-28-2014, 07:26 PM   #717
Bomp
Bomp's Avatar
What size of exhaust, mufflers and are you running it out the back?
Two major items getting crossed off the list.
Bomp is offline   Reply With Quote
Old 07-28-2014, 08:28 PM   #718
JonnyC10
Looks sweet! I need to find some trailing arms for mine. My drivers side is pretty rusty. Hope I can get some before my CPP drop kit gets here.
JonnyC10 is offline   Reply With Quote
Old 07-28-2014, 10:54 PM   #719
Xeen
Xeen's Avatar
Stainless 2.5" with an X-pipe and dual 3" body stainless resonators to the back of the cab then I'm thinking about going to aluminized from there and dump it in front of the rear axle.
The plan is to drive it around the block once the resonators are installed and see what it sounds like and decide if I want mufflers or not.
If it turns out I want mufflers then I will run stainless up to the mufflers then aluminized from there on and dump it in front of the rear axle.
Here are the resonators I'm using.
Old 07-29-2014, 01:07 AM   #720
gdavis
gdavis's Avatar
good work and I believe the exhaust is going to look sweet.
Check out Patches
Old 08-06-2014, 08:22 AM   #721
mcbassin
Still Learning
mcbassin's Avatar
I'm just using Master Pro hoses from O'Reilly Auto Parts and they seem to be nice quality.
See post #697 for the power steering hose high pressure side adapter info.
Thanks for the info.
Old 08-09-2014, 09:02 AM   #722
Xeen
Xeen's Avatar
Hey all;
After I have had ample time to think about it I have come to the conclusion that given the opportunity to do it all over again I would use factory location LS adapter plates and relocate the A/C compressor up to the top of the engine.
I spent way too much time, money and effort and whats worse other peoples time trying to keep it in the stock location and if I were to leave it there I would have to spend even more money to make it work so I'm going to go ahead and relocate it anyway so all that crap I did was a complete waste.
Lesson learned and hopefully someone else can learn from my mistakes and relocate it to avoid this mess all together.
Holley LS Truck A/C compressor relocation kit.
In case anyone would like a heads up on what you need to relocate the A/C compressor on their LS truck engine the relocation kit is made by Holley in several different configurations and is readily available.
https://www.holley.com/
Old 08-09-2014, 12:05 PM   #723
El Campo
El Campo's Avatar
That's sucks but we have all been there before . Good luck with it!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 08-10-2014, 12:49 AM   #724
gdavis
gdavis's Avatar
good luck Bryan. I to have had things go wrong as you know from my build so I heart goes out to you.
Check out Patches
Old 08-10-2014, 11:48 PM   #725
Xeen
Xeen's Avatar
What do you guys think of these wheels, they are US Wheel gunmetal sport mag.
The only thing I'm wondering is if a 4.5" backspace on a 18x8 wheel will clear the lip on the wheel well if I decide to slam the truck later.
1968, chevrolet, restomod, stepside, swb
