#1026 |
Re: 1963 C-10 in NC
Few more
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#1027 |
Re: 1963 C-10 in NC
Last of tow hook install and starting tie rods and main drag link. I did the pitman and idler arms before sway bar install.
#1028 |
Re: 1963 C-10 in NC
And there we have the completed front end. All new components, grade 8 bolts and a lot of prep and finish time.
#1029 |
Re: 1963 C-10 in NC
Last two pics for the day are of the driver side white wall installed. The 73 4x4 gm rims cleared the calipers just fine. Will get it down off the jacks tonight and get the lug nuts torqued down so I can get the caps on.
I can tell you for experience.....installing a new front end with all new painted parts alone is a challenge, but can be done. Now time for phase 2.....engine & trans
#1030 |
Re: 1963 C-10 in NC
Sharps40 was kind enough to install new ones before I got the crossmember, so I didn't have to. I'd check with him.
#1031 |
Re: 1963 C-10 in NC
Thanks Rich. A lot of blood, sweat, tears and $. And a few beers afterwards!!!
#1032 |
I'm just glad to be here!
Re: 1963 C-10 in NC
That front looks great! Really like the contrast between the flat undercoating on the frame and the gloss black and blue on the suspension parts.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#1033 | |
Re: 1963 C-10 in NC
Calling for rain the next 5 days....so engine/trans may have to hold off until the storms pass. I also installed all new grade 8 hardware anywhere I could get a new bolt/nut on. The crossmember install was probably the hardest part doing it solo....followed by the sway bar. I used wood clamps to hold the top of the sway bar to the frame which allowed me to get the a-arms measured up. Once bolted to the a-arms, the rest went fairly easy....just drilling holes.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 07-09-2014 at 09:58 AM. |
#1034 |
![]() Join Date: Mar 2013
Re: 1963 C-10 in NC
Looks good bud! Looking forward to seeing that engine sit perrty in that bay.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#1035 |
Re: 1963 C-10 in NC
Thanks TJ....me too!!
#1036 |
Re: 1963 C-10 in NC
Very Nice!!!
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
#1037 |
Re: 1963 C-10 in NC
#1038 |
![]() Join Date: Oct 2012
Re: 1963 C-10 in NC
#1039 |
Re: 1963 C-10 in NC
That looks great. I am going to have to stop by. I am selling my car this week then I am going to get my 62. I will drop the motor mounts off with you.
84 GMC One ton 4x4 454 4 speed 62 Chevy C10 short fleet plus about 13 previous gm trucks from 1960 to 2000 |
#1040 |
Senior Enthusiast
Re: 1963 C-10 in NC
Man I like how that front chassis looks. Nicely detailed for sure!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#1041 |
Re: 1963 C-10 in NC
I'm home most nights Eric. Just call 1st to make sure I'm at the house, but your welcome anytime.
#1042 |
Re: 1963 C-10 in NC
Thanks Mark for the kind words. I'm slowly learning patience as assembly on a freshly painted front end isn't easy. I'm normally like a bull in a china shop and I had to slow myself down for this phase of the build. Lots of tape, padding and cardboard were used. Did have some minor touch up, that's why all the cans are in the background of the pics. Tried to touch up as I went.
#1043 | |
Re: 1963 C-10 in NC
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle. |
#1044 |
Re: 1963 C-10 in NC
Haha....I had hoped to live up to that statement this weekend. Got a lot done, would always like more done, but I'll settle with what I got accomplished without dropping standards. Weather rolling in for the next few days, so engine may have to hold out a few days. But I'll keep the thread posted on progress!!
#1045 |
Re: 1963 C-10 in NC
Looks great man. I'm not sure if you mentioned it did you use stock front springs or are the lowered?
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
#1046 |
Re: 1963 C-10 in NC
Thanks BJ. The springs are stock height big block springs for the 63-72 model 1/2 tons. I think they are really a 3/4 ton spring by the look of it, but supposed to be a little stiffer to help with the additional weight of the big block.
#1047 |
Re: 1963 C-10 in NC
Pimpston65......heres the pics you requested. I tried to get some good pics of the mounting locations also for the bolts. Let me know if you need more.
#1048 |
Re: 1963 C-10 in NC
Few of the driver side set on the ground and the factory cap on. Will get pass side done tonight.....just had entirely too much going on last night.
I can't wait to see this color on the truck. Too bad my 1st set of trim rings were too loose on these rims.....I really liked the blue line between the white wall and the rim, but I went to a 2" trim ring and they are super tight....these will not come off easily. I think they still look good.
#1049 |
Senior Enthusiast
Re: 1963 C-10 in NC
I like the looks of the earlier design rings as well. I years gone by I had good luck tightening the trim rings by bending the prongs on the back to a more severe angle. But it may or may not do any good with disc brake wheels if the prongs land in the safety bead groove. Either way it's a nice look.
#1050 | |
Re: 1963 C-10 in NC
Both sets of rings were sold for 60-87 chevy 15" rims, but there are obviously some variants. I didn't try the 2" rings on the 3 nubs rims, but I imagine they would have fit on those as well....just maybe tighter than the 4 nub rims.
