Tub Contral Arms???
Im looking at some tub control arms and I need to know.
See im droping my truck 3"/4" but for where i live i need some clearance would tub's be the way to go???
Looking for 67-68 short step side body thats in great shape and suburban body thats in great shape and both have to be in tx Dfw |
Happy to be here
![]() Join Date: Mar 2000
I don't think you will have any problem with just a 3/4 drop. You might have some clearence issues with a bigger drop.
Also it depends on what size wheel you plan on running. If your going with a 15" wheel, then the cup on the A-arm might be a little close to the ground. With a 20" wheel the cups shouldn't be a problem even with a 5" drop up front... ![]()
with the chrome or Stanless steel tubs will it look alot better?
Careful, they attack...
What exactly is a tub control arm? Do you mean tube control arm? As in a dropped arm? If so, you might have a clearance issue with smaller rims. If you go to a 17 inch rim, you should be fine.
