07-06-2014, 06:41 PM | #1 |
What tire size for 17s
I plan on going with some 17 on my 64 c10 stepside but dont know what tire size to go with. Having trouble finding some trucks on 17 in these years. Any info would help
07-07-2014, 10:04 AM | #2 |
Re: What tire size for 17s
Your question is a little vague. Not sure exactly what you are looking to accomplish, so it's hard to answer. Do you want it to look stock, sort of? Are you going to lower it and want them to tuck? Do you want them as wide as possible? In the meantime, here's a link to a site that you can do some comparisons with that I have found helpful: http://www.miata.net/garage/tirecalc.html
07-07-2014, 10:09 AM | #3 |
67-72 parts collector,…
Tire size and wheel width are directly related.
What size wheels?
07-07-2014, 03:27 PM | #4 |
Looking at stock size 235/75/15 I went 235/60/15 and a 275/60 rear. Couldn't find 17s I liked. Went 18x9.5 and 18x8. 295/45/18 which is 28 tall and 11.5 wide Nitto 555s best bet use the the tire calculator on Discount Tire or other sites.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
07-07-2014, 03:30 PM | #5 |
One more.
07-09-2014, 12:27 AM | #6 |
Well I was planning on running 17 but I have a 72 12 bolt posi and its wider so I would need a bit of backspacing on a 17. The problem is that on a 8 inch rim I would need 5 inch backspacing to get it right on and finding a cost efficient wheel with that backspacing is pretty hard so Im sort of confused on what to go with now.
07-09-2014, 01:12 AM | #7 | |
Any pictures of the front or the entire package (front and rear?) I am planning the same boat (18x8 front, 18x9.5 rear.... LOVE what you have going on)
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
07-09-2014, 03:44 AM | #8 |
From a different thread.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
07-09-2014, 11:03 AM | #9 |
Waiting for PorterBuilt front to come back from powdercoat and brakes from California. Getting closer to having the front in and done but 245/40/18 for front. Had hard time finding 17s in right size gave up and went 18. Still meat on tire and right height and width.
07-09-2014, 04:36 PM | #10 |
5/5 drop with 275/55R17 in the rear and 275/50R17 up front
