Old 07-09-2014, 09:59 PM   #1
lahnen
loose tilt column
the tilt column my 89 burban over the last 2 weeks has gotten real loose, if I pull the wheel off is there something I can tighten up to fix it or should I look for a new column.
lahnen is offline   Reply With Quote
Old 07-09-2014, 11:11 PM   #2
tucsonjwt
Re: loose tilt column
Are you talking about the steering wheel itself or the whole tilt column? If it is the whole column, then there are two bolts under the dash that hold the column in place. I have had those left loose after "mechanics" worked on my truck.
If the steering wheel itself is loose, I am not sure. It really should not come loose because it is in place under a nut and the pressure of a metal plate, so I am no help there.
tucsonjwt is offline   Reply With Quote
Old 07-09-2014, 11:54 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
My bet is that you are talking about the whole tilt assembly flopping around within itself. The columns on these trucks had an issue with the four bolts inside the column housing coming loose and letting this happen. To fix this, you will need some specialized tools to get into the column a and remove and coat the bolts with lock-tight and then reinsert and tighten them.
You will need a steering wheel puller and then a tool to pull the pins out of the pivot assembly of the tilt mechanism. (See attached ). This trick is one that can frustrate you, since the small pilot bolt on this can break easily. You will also need an internal torx socket to get the bolts out of the column, so that you can clean them and re-install them.
http://store.snapon.com/Steering-Whe...--P635347.aspx
Frank
Old 07-10-2014, 06:28 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
you forgot the lock plate tool too.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-10-2014, 10:09 AM   #5
piecesparts
Yep, you are right. However, I have taken a steering column apart on the road with screwdrivers and cat bars, so there is a tool for that, but it can be done by hand with some ingenuity.
Here it is.
http://store.snapon.com/Steering-Whe...e-P647234.aspx
Frank
Old 07-10-2014, 04:35 PM   #6
tucsonjwt
Steering wheel puller can be borrowed from most parts stores, not sure about that other column tool.
Old 07-10-2014, 04:57 PM   #7
I just did mine, bought the tools at Napa.
Old 07-10-2014, 11:15 PM   #8
lahnen
yes the tilt assembly is whats moving around. thanks for the help guys. I always need an excuse to buy more tools so think I will do some shopping and hope I have no issues fixing it
Old 07-11-2014, 10:30 AM   #9
1774btcrew
1774btcrew's Avatar
When you do rebuild it take your time and degrease everything and use a good quality grease in reassembly. I have built roughly 20 of these columns and while it gets easier with each one it still seems like I forget a step every now and then and have to take it apart. Watch the videos a couple times and make sure you have a good clean work area where you can keep track of all of the parts.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
