Old 07-03-2014, 11:45 PM   #1076
sduckworth13
sduckworth13's Avatar
Re: Crusty Rusty Leaky Squeaky 67 Step
That bedside looks super nice Vic.
Scott
sduckworth13 is offline   Reply With Quote
Old 07-04-2014, 10:02 AM   #1077
Vic1947
Vic1947's Avatar
I wish it looked as good in person as it does in the photo, Scott. The seamed area toward the back will need a considerable amount of finesse to get it to look right. Best choice would be to leave it in primer like I originally contemplated.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 07-10-2014, 05:47 PM   #1078
Vic1947
Vic1947's Avatar
The last few days have been devoted to bodywork. The bedsides are ready for 2K primer as are the front and rear wheel wells. I've picked back up on the bed floor and even with my customized spreader tools, it's pretty tough sledding. There's a zillion dings in just about every place you look. The spray bed liner will hide a lot, but not the dents. I figure I have a couple more days of grinding down filler, then it should be ready for a coat of Slick Sand. I've been mulling over doing the undercoat and spray liner with the bed in primer and all assembled, but I haven't come up with a way to set it down on the chassis when the time comes. It gets pretty heavy when it's all put together.
Victor
Old 07-10-2014, 08:57 PM   #1079
Low Elco
4x4 across the bed at tubs, cherry pickerfrom rear, jack that dude right up.
Low Elco is offline   Reply With Quote
Old 07-10-2014, 09:00 PM   #1080
sduckworth13
Vic, I'm always ready to help whenever you need it. Just give me a call, I'm 10 minutes away.
Scott
Old 07-10-2014, 09:01 PM   #1081
bguild
bguild's Avatar
Vic I would be more than happy with the bed installation if need be.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline   Reply With Quote
Old 07-10-2014, 09:19 PM   #1082
swamp rat
swamp rat's Avatar
This is what i do with my 8' bed, i will say that it does stress the rails a bit, if you added some reinforcement under the rails i think with a 6' bed it would be no problem. I did note you have a cherry picker, you can fab up a lifting jig.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-10-2014, 09:45 PM   #1083
jlsanborn
jlsanborn's Avatar
Great update Vic! My bedsides are whacked in that same area and try as I might, still wound up with some thick filler there. I bet yours turn out sweet.
Assembled seems like the way to go. Maybe a couple 4x4's spanned across, under the bed rails, tied together with another underneath, down the center like an "H"? Find center of gravity front to back and snatch it there with the engine hoist? I've been putting four straps with S hooks under the four stake pockets but I think that'd be a little too sketchy for finished goods. Rolling the chassis under instead of trying to roll the hoist around is way more controllable too.
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 07-11-2014, 01:01 AM   #1084
Xeen
Xeen's Avatar
Vic you could build a rig in the up stairs garage ceiling and use a chain hoist with two frame chains and an anchor shackle to lift it, piece of cake.
Alternatively you could simply undercoat the floor then bolt it to the frame then assemble the header panel and sides then apply the spray liner.
You are almost there Vic, the finish line is right in front of you!
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 07-11-2014, 07:09 AM   #1085
Elliot949
Elliot949's Avatar
Dang... If you lived closer to me I have a bed lift that works with my Cherry picker...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 07-11-2014, 10:45 AM   #1086
Dean'smeanmachine
Dean'smeanmachine's Avatar
looking very good, i enjoy watching your build . your a pro hands down
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline   Reply With Quote
Old 07-11-2014, 12:15 PM   #1087
Vic1947
Vic1947's Avatar
Thanks everyone for all the good suggestions. I think maybe if I clamp the 1" square tubes I used to shorten the bedside to the inside of the top rails, it would make them sturdy enough to use 4x4's and the cherry picker. I know that when I first got the bed, I tried to pick it up by putting hooks in the stake pockets and they immediately began to deform. Course there are no stake pocket holes anymore. Back then, there were holes in the floor where Roy bolted in a chain for lifting, so I ended up using them, but they're long gone now too. Anyway, I think you've collectively provided me with a workable plan. Thanks again!
Victor
Old 07-14-2014, 06:51 PM   #1088
Vic1947
Vic1947's Avatar
More work on the bed floor over the weekend. Spread the last of the mud on the dings and dents, then sanded it down ...mostly by hand. I was just about out of Slick Sand with nowhere to pick some up on the weekend, so I shot what I had on the tailgate end of the floor and let it setup overnight. Today I made a trip to Wholesale Paint and brought home a gallon of Slick Sand so I'd be ready for the change in the weather. If you can stand a few more pics of the floor, just wanted to show the before and after working the polyester filler. It does a great job of filling sand scratches and pinholes. Tomorrow I'll tune-up the spray gun and squirt the entire floor and then it's back to sanding on it one last time. It will then get a heavy coat of 2K primer and be ready for the spray in bedliner.
Victor
Old 07-14-2014, 07:52 PM   #1089
swamp rat
swamp rat's Avatar
Lots of work, but looking good!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 07-14-2014, 08:02 PM   #1090
Xeen
Xeen's Avatar
x2
Old 07-14-2014, 08:15 PM   #1091
jeh
jeh's Avatar
Looks good Vic, hard work always pays off!!!!
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 07-14-2014, 08:31 PM   #1092
Elliot949
Elliot949's Avatar
I feel your pain on the floor Vic... I am doing the same thing to my Repop Floor...
Old 07-14-2014, 10:36 PM   #1093
sduckworth13
I feel like I'm visiting a high end bodyshop every time I visit you Vic. All the work you've done looks top notch. Thanks for all your help trying to sort my overheating issue out, I appreciate it very much.
Scott
Old 07-14-2014, 10:49 PM   #1094
Bennett68C10
Bennett68C10's Avatar
Nice job on the bed floor, it takes a lot of patience and skill to make it look that nice.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 07-14-2014, 11:10 PM   #1095
RatRod68
RatRod68's Avatar
oh man Vic, I feel your pain. We fixed every single dent and ding in my Dad's bed floor, and then he covered it up with carpet
build Threads:
Nasty 68 C10. My lil hotrod
Leftovers 68 C20
D-Ranged Ford Ranger on steroids
Semper Fi
RatRod68 is offline   Reply With Quote
Old 07-14-2014, 11:16 PM   #1096
RatRod68
RatRod68's Avatar
build Threads:
Leftovers 68 C20
Semper Fi
Old 07-15-2014, 07:58 AM   #1097
mcbassin
Still Learning
mcbassin's Avatar
Nice work on the floor Vic. I know how dang time consuming that can be. I think the results speak for themselves.
Old 07-15-2014, 11:11 AM   #1098
Dean'smeanmachine
looking good!
Dean
in God we Trust
Old 07-15-2014, 01:08 PM   #1099
Low Elco
Floor looks good!
Old 07-15-2014, 06:02 PM   #1100
Vic1947
Vic1947's Avatar
Thanks for all the comps, guys! The weather has turned positively gorgeous for the next few days, so I'm hoping to make a lot of progress on the primer front. After laying down a nice thick coat of Slick Sand on the entire bed floor I used spot putty to fill up some small chips and low spots I figured might show. Will resume sanding tomorrow after the pookie sets up. My goal is to have the undercoat on the bottom side done and the bed assembled and ready to spray bed liner by the first of next week. The shop was getting covered in dust, so I took some time to move things around and do a quick cleanup with the air nozzle. Looks a little better than it did, but it's a never ending battle.
Victor
