View Poll Results: Which rear end? | |||
14 Bolt Full Floater with 3.42s |
2 | 20.00% |
Rebuild the Dana 60 |
1 | 10.00% |
Rebuilt 12 Bolt with 3.07s |
6 | 60.00% |
None of the above |
1 | 10.00% |
Voters: 10. You may not vote on this poll |
![]() Join Date: Apr 2007
Opinions needed on upcoming CST Blazer Build
So I need some opinions here. I have decided to change direction on my 68 GMC K20 build (in my signature), and put all of the parts I've bought for that into my 71 CST K5. The drivetrain will be a HT383 GM Crate Engine with a custom Mass-Flo EFI system mated to an NV4500. What I need help on is the rear end choice.
I have a new full floater 14 Bolt in the truck that has 3.42 gears. I also have a very used rear Dana 60 from a 72 GMC K20 with 4.10s and a locker. I'd most likely rebuild the Dana 60 with 3.73 or lower gears as the Blazer is not going to be a hard core offroader but rather a daily driver with lots of highway use. I also have a rebuilt 12 Bolt already in the blazer with 3.07s, but I am pretty sure that is my last option. Which would you go with and why? Is the 14 bolt overkill for the blazer?
Maj USAF 71 K5 Blazer CST 72 K20 HT383 NV4500 Mass-Flo EFI 71 K10 LWB 52 Dodge Power Wagon 67 Dodge WM300 Power Wagon 48 Dodge WDX Power Wagon My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=239487 Last edited by Rust Buster; 07-08-2014 at 09:51 AM. Reason: Edit |
![]() Join Date: Jan 2001
Re: Opinions needed on upcoming CST Blazer Build
In my opinion, for the type of use you're planning, the 14 bolt is more than you need. I've actually considered the same swap (I have 1t front and rear sitting out back) but I just don't use my Blazer that hard off-road, mostly dirt roads and trails.
I'd be interested to hear other opinions, because I'm still in the initial stages of my build. |
Carpe manana
![]() ![]() Join Date: Dec 2010
What size tires are you planning to use?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Current plan is 32s. That's what I have on their now and I like the stance
Maj USAF 71 K5 Blazer CST 72 K20 HT383 NV4500 Mass-Flo EFI 71 K10 LWB 52 Dodge Power Wagon 67 Dodge WM300 Power Wagon 48 Dodge WDX Power Wagon My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=239487 |
Why is the 12 bolt your last option? For a daily driver? The gears? If it was mine, and I was building a daily driver that will mainly be highway driven, I would go with the 12 bolt. If I needed to change gearing I would do so in the 12 bolt. Probably run 3.73's with that trans.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
I would think the 12 bolt would be your first choice. It can be built to be strong and light.
You're using 32" tires, not thrashing off-road and running highway miles, all perfect for the 12 bolt. The 14 or 60 are heavy, strong, but power and fuel abusing axles, not what you need for your claimed use.
1972 Blazer build: http://67-72chevytrucks.com/vboard/s...d.php?t=615744 Last edited by 67Steven; 07-09-2014 at 12:20 AM. Reason: syntax error |
![]() Join Date: May 2007
I used to do a lot of rock crawling with my blazer, with 36 inch swampers, a locker, 4.10 gears, and aftermarket axles in the 12 bolt. It never gave me any grief, untill I was goofing around in 2 low, and bent a spring perch trying to to climb over about a 3 foot bank.
For what you intend to do, I wouldn't hesitate to use the 12 bolt!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
For highway, use the 12bolt. Probably 3.73 with the 32 tires. Go to grimjeeper dot com and use their calculator to figure out engine rpms at different speeds. Excellent website with easy dropdowns that include the nv4500 and np205. Just be sure once you figure your engine rpm's in 5th gear at you highway cruise speed, that the engine you have will cruise happy at that rpm based on cam usage range.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
#9 | |
#10 | |
I am posting all this as my opinion. PLEASE CONFIRM ALL NUMBERS YOURSELF. website link: http://www.grimmjeeper.com/gears.html Cheers. [IMG] ![]() [IMG] ![]()
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 Last edited by tjsblazer; 07-10-2014 at 08:04 PM. |
Cool website!
I put in my numbers (with the current TH350 and planned 700R4) and with the 700R4 if I can get the engine up to 6000 RPM I should be doing 226 MPH! What's the take-off speed for a 72 Blazer? |
Ah! You left out the extra "m" in grimm when you wrote the first time. Awesome tool and thanks for passing along, it will be getting bookmarked!
I think it would get a little scary about the 85-90mph threshold.
Yes. Input your 3.07 stock gears. I wonder if you would really use 5th gear much with that combo.
#15 |
Apparently not! man...decisions decisions...
#16 |
I have the 12 bolt 3.07 rear in my 71 K5 with 33" tires now. It is a little slow on take off, but works great running with 70 mph traffic on the interstate. With your tire size preference and daily driving I would recommend the 12 bolt. I should also add that mine is 350 mild build V8 and 350 auto (3 speed) trans. Enjoy the build!
#17 |
I'm restoring my k5 right now and swapping to an NV4500 also. I'm doing driveline test fit on Monday. Ive decided to run 4.56 gears on 33" tires. My highway cruise will be around 1900-2000. Just high enough to get in to the range of my cam although it is quite a bit taller and longer than the cam in your set up.
