Old 07-10-2014, 11:55 PM   #1
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Re: 60-66 Tire/Wheel Pics
Originally Posted by kenwkirk View Post
I have a 1966 c-10 Fleetside I am currently running 15x8 truck rallys with minimum clearance -- fender wells have been barely trimmed --- I am wanting 2 go with the BOSS 338 ---17x8 front & 18x9.5 rear --- truck has been lowered 4" front & 6" rear,, but it is on a 1972 frame --- will these wheels fit with the correct back-space ? if not does anyone have any suggestions/opinions on what will fit ? THANKS IN ADVANCE
Im sure the 17X8 will fit as well as a 18X8 without any problem other than cleaning the snout up on the brake rotor .... very common issue with 1.25'' brake rotors that a 1972 is going to have. Im guessing the 18X9.5 on the rear maybe to much. They do have 5.25'' backspacing and no other options. the 17X8 and 18X8 have 4.5'' backspacing. You could get a 20X8.5 with 4.75'' backspace , might get a little closer to fitting. they do offer a 20X8.5'', 5.25'' backspace wheel as well which Im positive would fit in the rear. I dont have a ton of experience working on the 66 and older trucks tho.
Im sure someone will chime in here.
Dont forget if you have a 1972 frame you should have the wider rear axle if nothing has been chahged there.
ksbrktracer is offline   Reply With Quote
Old 07-11-2014, 07:19 AM   #2
SteveMiller
SteveMiller's Avatar
18x8 235/60 & 18x9.5 275/55 on American Racing VN805's.
4.8 LS
4wheel disk on 84square suspension swap.
Oh yeah. 5" drop coils in rear, and cut one front coil w/drop spindles front.
SteveMiller is offline   Reply With Quote
