07-10-2014, 11:56 PM | #1 |
Ac condensor
So I am running a serpentine system on my 77 c10. Truck had factory ac, but now the compressor is Rh mounted, and all the lines on condenser are Lh.
Question is, what condenser are guys running that have Rh lines, so I don't have lines running all over the engine bay. Thanks |
07-11-2014, 04:24 PM | #2 | |
Re: Ac condensor
07-11-2014, 05:47 PM | #3 | |
Re: Ac condensor
My '83 and '87 have the lines on the passenger side. The van serpentine setup has the a/c compressor on the drivers side where it was, not that it helps you now that you already have those parts.
07-12-2014, 06:27 PM | #4 |
Re: Ac condensor
Got one from an 85, the lines are on passenger side, and it should fit with some mods, and homemade mounts.
