new to forum
hi guys I am new to this forum thing but I think I could really use your help. I am starting to gut out the whole cab and start to restore everything inside. there is a lot of old dirt, grease etc. inside has anyone found a great way to clean it all out. I don't have the money to have it sand blasted. I was just going to go through and clean everything by hand and sand anything I need to. I think this is how I can show pictures of it.
thanks appreciate the insight. johnny http://67-72chevytrucks.com/vboard/a...1&d=1405032531 http://67-72chevytrucks.com/vboard/a...1&d=1405032531 |
Re: new to forum
Get to work! Wire brush, degreasers, tooth brushes, shop vac etc.
Re: new to forum
Welcome to you from eastern parts of Arkansas. It looks to me you got a better start than some elbow grease and soap and water will go a long way there. Jim
Re: new to forum
Stuff like Simple Green, a whole bunch of rags, scrub brush, and elbow grease.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
Re: new to forum
Welcome. Looks like you have a good start. Scotch brite pads work well for cleaning and scuffing prior to painting parts.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
![]() Join Date: May 2012
Re: new to forum
first let me welcome you to the forum from Texas, like said above lots of el bow grease is good , simple green works real good , I like full strength and let it set a while...good luck on your truck.
Re: new to forum
What about smaller sand blasting gun? Has anyone tried it?
Re: new to forum
Thats good for removing surface rust from small parts, but for large areas it takes forever and makes a mess. Plus you need to use a respirator.
Re: new to forum
soap and water baby! haha I am in a similar situation right now and I am going to douse things with some simple green and hose her out!
Also good old SOS pads may take some time but they work wonders. I just got done doing my whole entire ceiling inside my cab that had some surface speckling looks way better now. |
Re: new to forum
Welcome to the forum from Phoenix...
