Re: What Did You Do With Your Truck Today ?
Cut the step loose and pushed it down, sill stayed level and parallel with the door bottom. Still needs welded and hammer and dolly work and door gap set but much closer.
A320 Pilot/USAF Retired
Gave my 57 a facelift!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
![]() ![]() Join Date: Nov 2008
JJ, you know I love your truck but what are your plans? Are you turning it into a GMC step side or maybe a GMC Suburban Carrier? Those are more rare than hen's teeth as I'm sure you know.
I thought you'd posted awhile ago that you intended to make your truck into a Cameo, but now I'm a bit confused. She's still a GREAT looking truck!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
Dang Softpatch, I think what you really need is a few more leaf springs. What was that thing hauling, all the steel to build the Titanic?
Rob
My '47 C.O.E build |
My cab had been smelling like gasoline when I would fuel up. Large hose would leak no matter how tight the clamp was. So I ordered a set of hoses, and a new filler neck grommet, as the 60 yr old original was looking a bit tired.... Got them off the internet from Grumpys parts in Arizona. They arrived in two days! Hoses and grommet fit perfectly, just a bit of grunting, and a little lube, to get them on. 81 deg and 50% humidity here in So Cal today, actually had a tiny bit of rain!
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder" |
#6 | |
#7 | |
Are you missing pieces to complete the Cameo conversion? Since you're wheels are orange I'm wondering what your eventual final color scheme is planned to be? Orange two tone could look great. A little like a 50-50 bar!
Looks AMAZING!
What grill/front end is that? - nevermind, I found it!
1957 3100 - 235/4spd - CPP 3" front drop axle & disc brake kit, CPP rear suspension kit, 15x7 & 15x8 Corvette rally wheels Last edited by topdown99; 07-15-2014 at 11:14 AM. |
Got My column almost done . Made new shifter Knob & Made new Handle Boot.
. great looking truck .... Would like to know more about the wheels (Rim's) like the color.! what is it (orange) your handy work..? How did you do it Spraybomb.? Two stage ?. .Base-clear coat.? .........Thanks Sp
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
Thanks Sp! I bought the rims from Stockton Wheel, 15x8 fronts and 16x10 rear, and the were powder coated orange by them too.
