Old 07-13-2014, 10:59 AM   #1
desertnick69
desertnick69's Avatar
What is it?
What is it? and what should it look like?
Any thing would help!
desertnick69 is offline   Reply With Quote
Old 07-13-2014, 11:12 AM   #2
Bigdav160
Bigdav160's Avatar
Re: What is it?
Shifter stuff at the automatic transmission, The bent up thing with the point bolts to the frame, the other piece bolts to the transmission shift shaft
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-13-2014, 11:14 AM   #3
jjzepplin
jjzepplin's Avatar
Re: What is it?
Yup. Looks to have been in a serious accident LOL! Auto trans linkage.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-13-2014, 11:54 AM   #4
FirstOwner69
FirstOwner69's Avatar
Re: What is it?
Here are 3 pictures from my teardown that should help. This is on a TH400.
FirstOwner69 is offline   Reply With Quote
Old 07-13-2014, 03:20 PM   #5
desertnick69
Re: What is it?
Thanks, The wreck it was in sheered the transmision mount off of the frame not the trans housing. Anyway does any one have any dimentions for these parts? Exspecialy the one with the twists, don't know that it will bend back without braking. If i could get the measurement from bolt hole to bolt hole would help.
Old 07-13-2014, 03:35 PM   #6
desertnick69
Re: What is it?
Should this be striaght?
Old 07-13-2014, 05:16 PM   #7
FirstOwner69
Re: What is it?
5-1/4" center to center.
Here's another shot showing the nuts on the 2 bolts that retain the bracket to the frame. It's a 3/4 ton if that matters.
Old 07-13-2014, 05:17 PM   #8
FirstOwner69
Re: What is it?
Yes. The surface with the notches should be parallel with the surface with the hole.
Old 07-13-2014, 06:11 PM   #9
desertnick69
Re: What is it?
Thanks for the info.
