Old 07-13-2014, 07:53 PM   #976
dug224
dug224's Avatar
Re: Lurker OrrieG Progress Pics
Hate to see you go backwards with finished paint but you nailed it. dug
dug224 is offline   Reply With Quote
Old 07-13-2014, 08:15 PM   #977
Kim57
Kim57's Avatar
Fix came out nice.
To bad it was after paint.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-13-2014, 10:31 PM   #978
OrrieG
OrrieG's Avatar
I still need to paint the doors, etc so only challenge will be blending. Down in the step it will not be too obvious.
Old 09-06-2014, 06:56 PM   #979
MIKESAD50
OrrieG,
Sure asked alot of times, as far as chassis coating, is yours paint or powder coated?
If painted what did you use?
Mike
MIKESAD50 is offline   Reply With Quote
Old 09-07-2014, 01:00 AM   #980
OrrieG
OrrieG's Avatar
Striped the frame, POR-15 in a few areas, nason primer, nason single stage Chassis Black 3 coats.
Old 09-13-2014, 08:20 PM   #981
OrrieG
OrrieG's Avatar
Put the fenders and doors back on to adjust gaps, drivers went fine, need to drop it just a little. passenger was a challenge. Got the fender to cowl and gap to door at the top fine, but bottom over lapped the door about 3/4". After a few evenings of pushing, pulling got it good enough for me. I remembered that when I pulled it apart it had been hit where the bottom front of the fender, grill surround and inner panel all come together. I straightened out all the bent metal, but suspect it was left in that configuration by the PO's body man to get stuff to work. I probably bent some of it back (had to use the porta power and BFH to relieve tension so stuff would not just snap back). Not perfect, but these trucks were not from the factory so good enough for me. I also dropped the hood on to make sure I was not getting things to where it would not fit, without the hinges connected or springs if fits just right assuming the correct gaps from all the rubber bumpers, etc. Now it back to finishing up the body work on the fenders and bed sides.
Old 09-13-2014, 08:50 PM   #982
OrrieG
OrrieG's Avatar
Here are photos of the drivers door btm and step after welding up the gap, etc.
Old 09-14-2014, 01:15 AM   #983
Kim57
Kim57's Avatar
Looking pretty good.
Kim
My build thread
Old 09-14-2014, 02:13 PM   #984
_Ogre
_Ogre's Avatar
one thing about these trucks is they flex a lot
any where my gaps are close, the paint inevitably chips
one issue i have is where the curved A pillar meets the door
i suggest you widen this gap
the tf A pillars should be renamed C pillars
shop air compressor timer
Old 09-14-2014, 04:07 PM   #985
OrrieG
OrrieG's Avatar
Good eye, I noticed the same, will drop the door a little. Maybe "reverse S" pillar. I pity the poor guys up north that have them rusted out and have to get them replaced and correct. Drivers side is still a little tight at the top radius, but I need to drop that door too.
Old 10-23-2014, 09:46 AM   #986
reaper71
reaper71's Avatar
Cool back story on the truck! nice build keep it up!!
Mark...
reaper71 is offline   Reply With Quote
Old 10-23-2014, 07:54 PM   #987
OrrieG
OrrieG's Avatar
Thanks, kind of stalled now, but expect a cash infusion soon.
Old 10-23-2014, 08:08 PM   #988
sgtusmc
sgtusmc's Avatar
It's looking great!
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 12-05-2014, 10:24 AM   #989
reaper71
reaper71's Avatar
Cash Infusion!!! I NEED ONE OF THOSE TOO
Old 12-06-2014, 03:45 PM   #990
OrrieG
OrrieG's Avatar
Made some decisions that will help in a couple of months.
Old 12-07-2014, 02:04 PM   #991
_Ogre
_Ogre's Avatar
selling your soul, orrieg?
Old 12-13-2014, 08:46 PM   #992
OrrieG
OrrieG's Avatar
Welded a vent connection on to the filler neck. Reviewed parts to buy list. Dug out the title so I can get fire and theft insurance back on the truck, agent says its no longer "parts" covered under the homeowners policy.
Old 01-11-2015, 09:10 PM   #993
OrrieG
OrrieG's Avatar
Back at it, here is a pic of the filler with vent.
Started the AC condenser install. Got a Vintage Air condenser kit for 55-57 because I wanted the dryer on the engine side, 58-59 puts it in prominent view on grille side. I knew the radiator support was different so the grommet hole ending up in the vents was not a surprise. Here are the issues and fixes.
1. I used a big truck radiator, it is 1" deeper. I had not noticed that GM added the equally to each side, pushing the core past the support. This interferes with the VA bracket, which I trimmed to miss the core.
2. The 58-59 radiator support is about 3/8" deeper, at least the one I have is it came out of a GMC, maybe they were different. After checking the clearance for the hose I shimmed the condenser 1/2" off the VA bracket which moved the condenser forward so the fitting would clear (almost). Still had to massage the bracket a little for the fitting nut to turn.
3. VA's hole measurements were off, glad I checked with lines before cutting.
4. Dryer bracket was way off, had to redo the clamp holes.
Here are pics of the mock up, bumper I messed up my nice paint but glad it fits, now need to get the hoses fitted.
Old 02-14-2015, 08:37 PM   #994
OrrieG
OrrieG's Avatar
Finally warmed up so I did my sun visors. First had to enlarge the panel to match the original driver side. The small one is what I got from Classic, they swear it is original and I must have some rare larger optional one. Drilled out the rivet, made a new one out of 1/8" masonite, pop rivet it back. Next cut head liner foam as padding. Next made a pattern so it would drop over the top with blind stitches on end and bottom. Tried french seam on trial but sewing machine foot would not work right. Went to local hot rod upholstry shop and they said they do not do visors for the same reason, all hand stitching and too much time.
Next sewed the end nearest mirror, along bottom and up the other end about 1/2" inside out. Left about 1" of material hanging out of the outside end. Turned it right side out and stuffed the visor panel in. Then, going about 1" at a time, rolled the remaining fabric and used superglue to fasten it. I'm happy, have about $15 in materials, it matches the rest of the interior and will keep the sun out of my eyes.
Old 02-14-2015, 09:25 PM   #995
Kim57
Kim57's Avatar
Looks real nice.
Kim
My build thread
Old 06-28-2015, 07:02 PM   #996
OrrieG
OrrieG's Avatar
Been slowly working on the AC and finally got all the lines done. In the process had to change compressor (did not notice I had bought an R12 unit instead of R134) which required some redoing of the lines. I used the 55-57 condenser, dryer and line set from VA. The 55-57 radiator support is different than 58-59. The filler panels on the sides have different configuration for the louvers which means the hole for the lines lands in the louver instead of a flat place, but I wanted the dryer on the engine side. Also I had to shim the condenser about an inch so the lines could attach to the condenser, maybe the early supports are narrower too?? This required shimming the X brace out too as shown in the photo. Do not know if functionally it is as strong but wanted to retain the look. Here are some pics.
Old 06-28-2015, 07:06 PM   #997
OrrieG
OrrieG's Avatar
Worked some today, installed the shift bezel. The 82 Eldo shift used a cable to move the indicator in the bezel. I got an original 64 Chevelle unit with repop graphics to work with the TH350. Need to touch up the paint and add the pointer. Did I mention its a bit warm?? Garage was only 90...
Old 06-28-2015, 07:21 PM   #998
dug224
dug224's Avatar
Man...glad to see you are still making progress.
Old 06-29-2015, 01:45 AM   #999
Nut Case
Nut Case's Avatar
OrreG Maybe a small triangle gusset could be welded to the spacer only might give it more strength, just a thought. Great work you have provided lots of good information. Thanks NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 06-29-2015, 09:21 AM   #1000
solidaxel
solidaxel's Avatar
When I changed compressors from R 12 to R 134 I was told to change the oil in the compressor.
I like your hard lines from the condenser to the evap
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
