Old 07-16-2014, 12:45 AM   #1
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: Outer Axle slinger woes
Here is how I am going to run the new parts and reuse the bronze washer. Seal 19992 cross references with an original that I took out. I think the small seal is in the right place? Seems like it given the 19992 seal keeps the grease in the inboard side of the needle bearing. Almost feels like its not needed if the whole shaft/inside of spindle is all well lubed with grease.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 07-17-2014, 01:12 PM   #2
swamp rat
swamp rat's Avatar
The reason to smear grease is just to minimize rust on the parts.
Ya know what bothers me about my thread now? i posted that i did use the V seal but i know i used the Nat 472397 on the inside of my hubs so it makes using the V seal impossible, plus i still have the BK1 kits .. Humm..
When i was dealing with this issue i do remember the NAPA guy was working off a parts breakdown and did a bunch of cross referencing and he also came up with the same National seal i ended up ordering The problem is i cant recall which breakdown we were working with. Whoever installed the seals in my hubs before me totally destroyed the part number so i ended up just measuring the hub ID and the slinger sleeve OD and did a lot of calling around. I think i also called the replacement hub manufacture. And i think Rock Auto may have come up with the seal number as well.
Informational thread.
http://www.pavementsucks.com/tech-article-14.html
PDF:
http://d44tech.com/dana44_1972_service_manual.pdf
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
