Old 07-15-2014, 11:13 AM   #1901
Dean'smeanmachine
Dean'smeanmachine's Avatar
Re: 1968
coming along nicely !
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline   Reply With Quote
Old 07-15-2014, 01:11 PM   #1902
Xeen
Xeen's Avatar
Re: 1968
The truck looks great George.
At this point I think you need to hear the engine run to put a little spring in your step so the next parts you should order are what ever you need to make it run.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 07-15-2014, 07:02 PM   #1903
gdavis
gdavis's Avatar
Re: 1968
Bryan, Dean, swamp rat. Thanks for stopping by and giving me a little encouragement on my build. I was getting a little baffled. But, that is all behind meat this point. I did made a deal with Bryan on his rear chrome bumper. I did order a set of NOS bumper braces for the front from a fellow boar member.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 07-15-2014, 07:45 PM   #1904
gdavis
gdavis's Avatar
Re: 1968
Here are some pictures of the inside of my truck. I still need to get a AC switch and the radio and then the dash will be done. except, for the wiring as you can see hanging down.
Check out Patches
Old 07-15-2014, 07:49 PM   #1905
gdavis
gdavis's Avatar
Re: 1968
more pictures and one of my grand daughter which was helping me as you can see, until I use the air compressor and then she heads for the hills. She asked me If I know how to drive a truck. I told her I could figure it out and her reply was is this why you are building you a truck. What comes into a child's mind.
I need a set of door handle gaskets so I can mount the door panel on the door. And a new steering wheel. This is the same steering wheel that came with the truck.
I figured it will work until I get the bugs worked out of the truck.
Check out Patches
Old 07-15-2014, 08:21 PM   #1906
Xeen
Xeen's Avatar
Re: 1968
The interior looks really nice George.
Did you order the rubber bumpers for the door jambs?
Old 07-16-2014, 12:09 PM   #1907
gdavis
gdavis's Avatar
Re: 1968
yes I did two per door. There is a third hole in the jam, so I figured I might put the third bumper in the hole what do you think?
Check out Patches
Old 07-16-2014, 01:27 PM   #1908
Xeen
Xeen's Avatar
Re: 1968
I would just put it back to factory specs which is two per side, don't add anything that isn't necessary.
Old 07-16-2014, 07:04 PM   #1909
gdavis
gdavis's Avatar
Re: 1968
I just to plug the hole in the jam that all.
Check out Patches
Old 07-16-2014, 07:15 PM   #1910
gdavis
gdavis's Avatar
Re: 1968
Well, Today I got my back up light down and worked on them, painting them up. It rained all day anyway. And it supposed to rain until Friday. So I worked inside of my shop today.
Guys today I talked to Vic and he said that electric choke carb come with there own choke system. So if any of you guys are thinking that you have to use a manual choke, well you don't. The carb has two plugs one - and one +. just connect the post to your ignition switch (hot) when key is on and the - post to a ground and you are in business.
here are a couple pictures of the back up light painted. as you can see I painted inside of the lights white. and the outside black.
They turned out real nice. These I got from Bryan (Xeen). he made the mounting bracket with a help from another board member. So, I lucked out with these. Thanks Bryan.
I will mount them on the truck in a day or two. I would like them to dry completely first.
Check out Patches
Old 07-16-2014, 11:06 PM   #1911
colgad
colgad's Avatar
Re: 1968
George, just found your build, we have been building our trucks about the same time. I have loved watching your build, you've been doing a super job. I only live about an hour south of you and were about the same age (I'am 63). I know what you mean about back issues too, no fun.
I am almost done with my 67 and hope to be on the road this month. I have an oil pan leak and can't seem to make it stop. We will have to meet once we have ours on the road!
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 07-17-2014, 03:50 PM   #1912
gdavis
gdavis's Avatar
Re: 1968
Sounds like a plan. I am still working on the ole girl. I have to install the exhaust and carb and all the electric wiring. I hope to have it on the road this year. Thanks for stopping by and reading my build. George
Check out Patches
Old 07-17-2014, 04:32 PM   #1913
colgad
colgad's Avatar
Re: 1968
If you would like some help with wiring just let me know. As long as were out of the direct sun I am up for it. Available most days, just PM me.
Old 07-17-2014, 11:36 PM   #1914
gdavis
gdavis's Avatar
Re: 1968
I sent you a PM
Check out Patches
Old 07-17-2014, 11:43 PM   #1915
gdavis
gdavis's Avatar
Re: 1968
Well, Today I finished up my back up lights. Then I finish up my floor supports in the bed. I am raising up my bed floor 5 inches. I got it in the truck with only 4 bolts. I need to get me some 1 x1 1/2 tubing for the support to the frame and bolt that to the frame with feet/tabs. I am glad that the paint job is not the finish coat. For I scratched it up some. I am going to weld the legs to the floor supports and put two on each piece of tubing. With all the bolts on each side and the front panel, that should be enough. The legs will be strong as can be. My tubing is 16 inch on center.
when all this is done I will have enough room to mount the gas lid to put gas in the tank.
Check out Patches
Old 07-18-2014, 07:22 PM   #1916
gdavis
gdavis's Avatar
Re: 1968
Well, today I found out there is a difference between the left and right tail gate chains. This is why I was having problems hooking the chains. I also mounted the back up lights on the truck.
Check out Patches
Old 07-19-2014, 01:34 AM   #1917
gdavis
gdavis's Avatar
Re: 1968
I hope to finish the legs from the new bed supports to the frame, maybe????????
Check out Patches
Old 07-19-2014, 01:32 PM   #1918
swamp rat
swamp rat's Avatar
Re: 1968
I didn't even notice the chains being different in the stepside bed i bought for my 67. Go figure.
Did you buy new lenses for the reverse lights?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-19-2014, 08:25 PM   #1919
gdavis
gdavis's Avatar
Re: 1968
I pulled the back up light back off the truck today. I had the weep hole facing up. It would not drain when it rained. So now the holes will be facing down when I re install the back up lights. Thanks Bryan for seeing that. I had to repaint the backing/mounting brackets. I had to reverse the brackets and the paint was bumed up. I will install the brackets back on Monday. I also got my bed supports level and bolted to the side wall and the front panel. I still need to attached three more bolts on each side. Then I will remove the bed off the truck and give it a good painting once again. But not until I have done all my wiring and everything else that needs to be done.
Check out Patches
Old 07-19-2014, 08:31 PM   #1920
gdavis
gdavis's Avatar
Re: 1968
No I bought a new set from Bryan in Ks. He had a great set with new streamline mounting brackets along with a new pair of lights. I have my old ones which is in perfect shape but no lens. I just wanted the set from Bryan.
I am happy the way they look on the truck. I wish I could afford the tail lights he has. But I will stay with what I have, His is stainless mine is steel painted.
Check out Patches
Old 07-20-2014, 12:53 AM   #1921
Bomp
Bomp's Avatar
Re: 1968
Been awhile since I've checked in on your build.
Wow
Your truck is looking great. Real attention to detail to make things right.
Your grand daughter is a sweet little helper and must think you are one smart fella being able to build his own truck to drive.
Bomp is offline   Reply With Quote
Old 07-20-2014, 01:25 AM   #1922
gdavis
gdavis's Avatar
Re: 1968
Wow
thanks Mr. Bomp I do try and thanks for looking and commenting on my grand daughter. I really like working with her. She says the smartest things. I worked with another grand son today. He is 8 and I had him under the fender doing the nuts for the bed supports. he likes to help.
Check out Patches
Old 07-20-2014, 09:45 PM   #1923
gdavis
gdavis's Avatar
Re: 1968
Well, today was Sunday so I rested and nursing my hand. I had a brain storm of a idea with my grinder. I removed the side handle and when I was using the wire wheel. You guessed it right. It got away from me and it took about 1/4 of hide off before I could let it go. But now I put the handle back on. I thought I could control the grinder, but my grip isn't what it used to be.
Check out Patches
Old 07-20-2014, 10:06 PM   #1924
colgad
colgad's Avatar
Re: 1968
Wow, that had to hurt! I have sanded my arm with an orbital sander but a wire wheel is whole other thing!
Hope you heal up quick.
Old 07-21-2014, 01:51 AM   #1925
gdavis
gdavis's Avatar
Re: 1968
yea it has been a few days since I did it and it is healing good. thanks
Check out Patches
