Old 07-16-2014, 11:36 AM   #1
gramps77
rejuvenating A/C system
need to replace my old compressor that is original to the truck and R-12. What else should I replace or have done while doing so?
gramps77 is offline   Reply With Quote
Old 07-16-2014, 11:41 AM   #2
Just call me Sean
Just call me Sean's Avatar
Re: rejuvenating A/C system
Expansion valve/orifice tube, accumulator/dryer.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 07-16-2014, 06:59 PM   #3
Skunksmash
Skunksmash's Avatar
I'd take it to someplace that will do it for a reasonable price and give you a warranty. New systems often leak and have to go back a few times before they're perfect. I paid $320 for everything when I had to redo mine. That's parts and installation. I got a 2 year warranty and it has gone back a few times when all the freon leaked out. And if it leaks, don't run the compressor or you'll kill it. Found that out the hard way. You'll notice the air not blowing as cold, or fading from cool to cold. That's when you stop using it and take it in for warranty work.
Skunksmash is offline   Reply With Quote
Old 07-16-2014, 07:05 PM   #4
hatzie
Moderator
hatzie's Avatar
What year is it?
Are you planning to refill with R12?
The 73-?? systems used a TXV rather than an orifice tube and are less tolerant of differing refrigerants.
If you have something that looks similar to this then you have the early TXV AC system.
The later Orifice valve systems are more adaptable and are a fairly easy to retrofit.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-16-2014, 07:08 PM   #5
hatzie
Moderator
hatzie's Avatar
Sounds like your Low Pressure Cut Off Switch is stuck or bypassed. The compressor shouldn't turn on at all if the pressure drops.
Old 07-17-2014, 12:30 PM   #6
gramps77
Originally Posted by hatzie View Post
What year is it?
Its a 77 and I totally forgot to check yesterday for that. It should be on the firewall box correct? Just at the bottom?
Old 07-18-2014, 02:04 PM   #7
hatzie
Moderator
hatzie's Avatar
It'll be on the firewall box. I've forgotten whether it's on top or bottom.
I Converted mine to the 80's orifice tube setup for Hydrocarbon refrigerant. But that's not for everyone... R134 will work OK at cruising speed with the right components.
