Old 07-14-2014, 11:07 PM   #1
Bueno 68C-10
Bueno 68C-10's Avatar
Question Help!!!!
I just bought the 12" drop spindle disc brake kit from cpp and installed it on my truck 68 c-10. I then got 73-88 4x4 steel wheels to accommodate for the disc brakes, but these wheels are rubbing the caliper. I would just like to know what other people do to either keep the steel wheel look or what 6 lug aluminum wheels people have used?? I open to anything, thanks in advance!!
Bueno 68C-10 is offline   Reply With Quote
Old 07-15-2014, 09:34 AM   #2
geezer#99
geezer#99's Avatar
Re: Help!!!!
Do you have a link to the kit you bought?
You might need a spacer or a little clearancing on the caliper.
geezer#99 is online now   Reply With Quote
Old 07-15-2014, 09:44 AM   #3
Bueno 68C-10
Re: Help!!!!
Yeah here is the link. http://www.classicperform.com/NewPro...opSpindles.htm
Old 07-15-2014, 09:54 AM   #4
geezer#99
geezer#99's Avatar
Re: Help!!!!
A little more specific would be nice!!
Old 07-15-2014, 10:21 AM   #5
Bueno 68C-10
Re: Help!!!!
It is the very first chevy truck kit labeled, Chevy Truck- 2" drop spindle.
Old 07-15-2014, 10:42 AM   #6
geezer#99
geezer#99's Avatar
Re: Help!!!!
Which wheels?
5 or 6 lug?
How close are they?
You might need an 1/8 inch spacer.
Old 07-15-2014, 11:55 AM   #7
Hook'em
Hook'em's Avatar
Re: Help!!!!
It's been 10 years or so, but when I added a disc brake kit to my truck, I had to get longer studs and spacers.
Hook'em
Hook'em is offline   Reply With Quote
Old 07-15-2014, 01:45 PM   #8
Bueno 68C-10
Re: Help!!!!
Here's some pics of where and what's rubbing. These wheels are also 6 lug btw. Name:  image.jpg
Old 07-15-2014, 01:47 PM   #9
Bueno 68C-10
Re: Help!!!!
Old 07-15-2014, 01:49 PM   #10
Bueno 68C-10
Re: Help!!!!
Old 07-15-2014, 03:15 PM   #11
SCOTI
SCOTI's Avatar
Re: Help!!!!
How much contact is being made? Is it something where you could grind a little off the caliper to clear?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 07-15-2014, 03:28 PM   #12
Bueno 68C-10
Re: Help!!!!
I'm not sure I will have to look when I get off work.
Old 07-15-2014, 03:28 PM   #13
geezer#99
geezer#99's Avatar
Re: Help!!!!
Most of your problem is centered on the fact that those aren't disc brake wheels.
Old 07-15-2014, 03:36 PM   #14
midnight rambler
midnight rambler's Avatar
Re: Help!!!!
i put spacers on my rally's
midnight rambler is offline   Reply With Quote
Old 07-15-2014, 05:46 PM   #15
Bueno 68C-10
Re: Help!!!!
They are 73-88 stock 4x4 wheels which I thought a lot of guys use those with disc brakes?
Old 07-15-2014, 10:47 PM   #16
Bueno 68C-10
Re: Help!!!!
Where do I get wheel spacers?
Old 07-16-2014, 12:00 AM   #17
geezer#99
geezer#99's Avatar
Re: Help!!!!
http://www.summitracing.com/int/part...p603/overview/
Or your local parts store.
Old 07-16-2014, 12:22 AM   #18
Bueno 68C-10
Re: Help!!!!
Ok thanks!
Old 07-16-2014, 12:07 PM   #19
SCOTI
SCOTI's Avatar
Re: Help!!!!
You are correct. 71-87 4x4 6-lug steel wheels clear disc brake set-ups. Pre 71 6-lug drum wheels don't.
I think the issue is just the particular combo of parts. Any way you could test fit a wheel on a buddys truck to see if there's an issue on an OE set-up? Or maybe try bolting on a 4x4 truck rally & see if you have the same clearance issue?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-16-2014, 11:12 PM   #20
Bueno 68C-10
Re: Help!!!!
Thanks for all the help guys I tried 1/4" wheel spacers and that didn't work so I just bought these wheels from Speedway Motors! http://www.speedwaymotors.com/Speedw...nch,70842.html
