07-08-2014, 03:16 PM | #1 |
Plumbing my LS
I'm running my fuel lines and was curious if this 10 micron filter was a good choice. I'm running an in tank pump with a return line.
http://www.summitracing.com/parts/hly-162-550
My 1972 K5 6.0 LTR 4L60 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=622068 |
07-08-2014, 03:47 PM | #2 |
Re: Plumbing my LS
I went with a gf652. It's a delco part and it's used on a ton of cars, so it's available pretty much everywhere
07-08-2014, 09:52 PM | #3 |
Re: Plumbing my LS
10 micron is good for the post pump filter.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-12-2014, 09:53 AM | #4 |
Re: Plumbing my LS
Thanks Hart Rod. I'm gonna tackle this plumbing today.
07-12-2014, 10:03 AM | #5 |
Re: Plumbing my LS
07-13-2014, 02:37 AM | #6 |
Re: Plumbing my LS
Looks good. If you don't have the AN line cutting tool I recommend using electrical tape and a cutoff wheel. I tried the hammer/sharp chisel method and didn't find that it worked that well at all. I just put a cutoff wheel on my 4.5" grinder and it worked awesome. I ran all AN flex line so had to do a lot of cutting.
07-13-2014, 08:16 AM | #7 |
Re: Plumbing my LS
I used duck tape and a cut off wheel doing mine
07-15-2014, 08:12 AM | #8 |
Re: Plumbing my LS
The tape/cut off wheel method, is what I did and it works great. Thanks
07-15-2014, 09:11 AM | #9 |
Boosted Member
Re: Plumbing my LS
Electrical tape and a band saw works well, too.
Make sure no matter how you cut it, you flush the lines out before you run the truck. You don't want all those bits of hose clogging up your injectors or your fuel filter.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
07-17-2014, 08:31 AM | #10 |
Re: Plumbing my LS
Yes, I am flushing out the lines for sure.
