Old 07-16-2014, 10:55 AM   #1
goose_on_fire
So, how badly did I wreck my transmission?
A couple brothers and I were pulling the engine, and since it's the first time we'd done it, we managed to miss a couple bolts holding the torque converter to the flywheel. Don't know how, but it happened.
When we cranked on the hoist, before we realized what we'd done, the transmission (TH350) bled out all over the driveway. Fluid everywhere.
So how badly did we likely wreck it? New seals, complete rebuild, scrap it and start shopping?
Just trying to budget for it in advance. Thanks guys.
goose_on_fire is offline   Reply With Quote
Old 07-16-2014, 11:09 AM   #2
R.L.
R.L.'s Avatar
Re: So, how badly did I wreck my transmission?
That doesn't sound bad at all, when the driveshaft is pulled from the transmission theirs nothing to keep the fluid from flowing out the tail of the trans. Before reinstalling change the trans filter remount it to the engine reinstall and then refill with new transmission fluid.
R.L. is offline   Reply With Quote
Old 07-16-2014, 11:10 AM   #3
R.L.
R.L.'s Avatar
Be sure to check the flywheel for damage, if it's warped it will need to be replaced.
Old 07-16-2014, 11:21 AM   #4
goose_on_fire
That's what I was hoping to hear. Will check the flywheel for flatness and go from there.
Thanks for the reassurance!
Old 07-16-2014, 11:22 AM   #5
Bigdav160
Bigdav160's Avatar
Most likely you just pulled the torque converter out of the pump.
Might as well put a new seal in there while it's out.
Key thing to make sure the torque converter is installed correctly before installing the new engine.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-16-2014, 11:42 AM   #6
wreckedchevy
wreckedchevy's Avatar
I'll second that. the first time i installed one didn't get the torque converter all the way in and broke the pump in the tranny
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline   Reply With Quote
Old 07-16-2014, 12:43 PM   #7
MARKDTN
I would put a new flexplate while it is out. Absolutely I would put a new front seal.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 07-16-2014, 01:07 PM   #8
davepl
davepl's Avatar
Agree. You can't just eyeball the flexplate and later spin it to 6000 rpm and expect not to lose a foot if its been bent even slightly. And you wouldn't know without a machinst's straightedge and some experience.
For the price of a flexplate, I'd put a new one on.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-16-2014, 02:17 PM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
You *could* have damaged the pump if the trans tried to drop as you were pulling the motor out. You won't know until you go to drive the truck. However, that's unlikely.
Like others have mentioned, at an absolute bare minimum replace the front seal on the trans (I guarantee it will leak and you will be pulling the trans if you don't replace it) and get a new flexplate. They're not expensive and to be sure you get the right one it should have a part number on it somewhere.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-17-2014, 02:05 AM   #10
goose_on_fire
Thanks, guys. I will definitely take your advice when it's going back together.
My first car was a '71 VW bus I rebuilt myself in high school, but this truck is a whole different animal (and I had "The Compleat Idiot" book by Muir to help me back then). You can't exactly drop a 350 onto a skateboard and wheel it into the garage like you could with the 1600cc VW engine... probably also explains why I called it a flywheel and not a flexplate.
Learning is fun, I'm glad this resource is here.
Funny story there. When I first got the truck (it was a college graduation gift and has bounced around the family for 10-ish years), there was this horrid rattling noise we couldn't figure out. I had family and friends over diagnosing it, doing the whole "screwdriver to the ear trick" trying to find the bad valve/lifter/whatever, and everyone was confused because it sounded like the noise was coming from *everywhere.* I got all sorts of differing opinions on what was causing the racket.
One day I crawled under the truck to check something unrelated, grabbed the flywheel (sorry, flexplate) for some leverage, and noticed that it wiggled. Like, a lot, back and forth. I torqued down the bolts, and the noise was gone forever.
The truck was clearly put together just well enough to sell at auction, which is the main reason behind the current rebuild. Fun stuff, thanks again.
Old 07-17-2014, 08:12 AM   #11
volksworld
well then the bolt holes are probably beaten out of round and the flexplate should be replaced anyway
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 07-17-2014, 08:25 AM   #12
67ChevyRedneck
I bought my truck when I was 15, like 18 years ago... I think I was 17 at the time, I got in the truck, pushed in the clutch, started it, then heard a really really really loud BANG! and my clutch wouldn't release all the way. After pushing it in and out a bunch of times I heard a weird rattling sound then my clutch released enough to grab and limp it the couple miles home. The clutch contact was so weak I couldn't even get up my parents driveway.
Got it home and looked under the truck. There was dent in the shape of a bolt head in the bell housing cover plate.
Removed the trans and found one of the pressure plates bolts was missing... then I found it jammed into my clutch. It somehow got loose, shot into the cover, bounced back, got into the pressure plate somehow and jammed between the clutch and the flywheel.
Jesse James
Project "On a Dime"
Old 07-17-2014, 11:10 AM   #13
BigMike
BigMike's Avatar
Whatever you do, DO NOT spin the flex plate on your finger to see if it is bent or not. I did it back in '83 when I was putting a trans in my wife's first car (17 yo GF at the time), a 68 Chevelle, and it about cut my damn finger off.
BigMike is offline   Reply With Quote
