Old 07-17-2014, 04:34 PM   #1
tincan1966
tincan1966's Avatar
Re: Battery Cut-Off Question
As with my own personal truck, I am using a negative output from my alarm system to trigger a relay that will interrupt the circuit from the horn relay to the ignition switch when I "arm" the alarm. My BATT power to the alarm is run separately from the starter, thru a fuse, to the alarm itself.
I am running a 6 channel alarm system, so I have several optional outputs I can use for various other functions.
But to answer your question, LostMy65, YES it can very well be controlled by a keyfob type system, such as a very basic 2 channel keyless entry, but utilizing the outputs for different functions. Most of these systems use a negative trigger output, and built in circuit protection and relays, making designing a system a lot easier.
tincan1966 is offline   Reply With Quote
