Old 07-17-2014, 05:59 PM   #1
vin63
It's Better With Nitro
vin63's Avatar
Re: Battery Cut-Off Question
This is what I have to use on my race cars with a battery. I also run one on my truck since I moved the battery to the rear under the bed (and I've run my truck at a local 1/8-mile drag strip from time to time). My battery disconnect switch is presently mounted behind the rear bumper, but for a street vehicle you can mount one just about anywhere. There are plenty of wiring diagrams on the Internet for the switch that you end up using.
http://www.jerrybickel.com/batteries...-switch-1.html
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
