Old 07-18-2014, 10:39 AM   #1
scuderia
scuderia's Avatar
What drive shaft do I look for?
So just installed a SM465 in my '66 C10 shortbed. I understand I need a driveshaft with a slipjoint. Can someone tell me what trucks would have a compatible driveshaft that I can try and source used? Thanks a bunch
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 07-18-2014, 11:14 AM   #2
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
Re: What drive shaft do I look for?
Any of the 60's 70's and I think early 80' swb trucks that had that transmission will work. Its hard to find a used one. The wrecking yards use forklifts to move vehicles around and destroy the drivelines with the forks. I finally resigned myself to just having a driveline shop make me new ones. Usually costs me between 300 and 500 bucks depending on what it is.
Oldtruckfanatic is offline   Reply With Quote
Old 07-18-2014, 11:14 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
A driveshaft is one of the items that I always buy new. There are a couple of good driveshaft shops in SF, and I would talk with them about your application and what you need.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-18-2014, 11:52 AM   #4
scuderia
scuderia's Avatar
thanks! any particular shop you've had good luck with?
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
Old 07-18-2014, 11:53 AM   #5
scuderia
scuderia's Avatar
Thanks!
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
Old 07-18-2014, 12:18 PM   #6
vin63
vin63's Avatar
Frank Wallace comes to mind, but there might be shops located closer to you. I had a local shop to me build me a custom steel shaft for my truck that came to $300. For that kind of pricing, I cannot justify buying a possibly damaged used shaft.
Old 07-18-2014, 03:59 PM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I keep watching for those parting out on CL.
I think the SM465 started getting used in 67.
It replaced the SM420.
I myself am going to a th350, so I'm watching for shortbeds parting from 66 on.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
