Closed Thread
Old 07-19-2014, 02:37 AM   #751
tll74
"Junkyard Dog"
tll74's Avatar
Re: 100's of misc parts from the last 6 trucks parted out
Originally Posted by 71 super View Post
Tom do you have a standard cooling fan for a v8, a vacuum fitting for rear of intake for an automatic and a 67/68 washer bottle holder- it has the two ears that are vertical? If so I will take them- 1 some or all. Will Paypal ASAP, harold
Harold, I have all of it. fan 15.00 4 blade or multi blade flex. 67-68 or 69-72?, 5.00 vac fitting, single port or multi port (trans and P/B ports)? 10.00 washer bottle holder. Shipping 15.00
Originally Posted by rusted72' View Post
Tom-
I need a set of alternator brackets and power steering brackets for a 72' with a 350sb.
trying to make my truck look as stock as possible.
if you do how much shipped to 90601?
I have the alt brackets 25.00, I only have the P/S brackets with a pump assy 75.00. Shipping on both 25.00 alt brackets only 15.00.
[QUOTE=tjsblazer;6766674]Tom, I am looking for a set of 4x4 exhaust hangers. One longer one midframe by the transfer case and one small one on the x-member above the rear axle. On Blazers for sure. Probably swb truck also. Unsure about other models. Do you have a set?
I have the front one. I'll check for the rear.
pics for VA72C10
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline
Old 07-19-2014, 08:07 AM   #752
71 super
71 super's Avatar
Four blade fan 67-68 , single port vac. Found a washer bottle bracket in box of junk that came with truck. Shot me Paypal and I will get you paid. Thank you harold
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline
Old 07-19-2014, 01:10 PM   #753
rusted72'
rusted72''s Avatar
sounds good, can i get some pics before i commit?
thank you
rusted72' is offline
Old 07-20-2014, 01:09 AM   #754
tll74
"Junkyard Dog"
tll74's Avatar
thank you
Sure, It will be next week though.
tll74 is offline
Old 07-20-2014, 10:03 AM   #755
67JimmyMO
67JimmyMO's Avatar
Originally Posted by tll74 View Post
I have not been able to get it removed yet and I need it off for weight and dimensions for shipping cost. I been preparing for a vacation with the family to CA and just ran out of time. I'll have clean slate when I return next week...
Any progress on this one yet (underbed spare carrier for 67 GMC SWB)?
Thanks, Jody
67JimmyMO is offline
Old 07-20-2014, 11:22 AM   #756
tjsblazer
tjsblazer's Avatar
Here is a borrowed pic of a set of hangers. The small angle one is from the xmember above the rear axle. Thanks for looking.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline
Old 07-24-2014, 08:02 PM   #757
Jake1971
Jake1971's Avatar
Tom, my antenna and hardware arrived today. Thanks again!
1971 Bone Stock C10 project "Jake"
1997 Sierra SLT factory short bed "Silver Bullet"
Jake1971 is offline
Old 07-26-2014, 09:57 AM   #758
Userone
Userone's Avatar
got any more radio deletes? i need one with brackets
Userone is offline
Old 07-28-2014, 09:49 PM   #759
JonnyC10
Trailing arms? Pics and price shipped to 03809? Thanks.
JonnyC10 is offline
Old 08-02-2014, 05:03 PM   #760
Jake1971
Jake1971's Avatar
Hey Tom, I am looking for one blue armrest for my '71 C10 and two unmolested tail light wiring harnesses from the firewall all the way back to the buckets. LMK total including shipping to 78602. Thanks again!
Jake1971 is offline
Old 08-03-2014, 01:46 PM   #761
Ccc925
Ccc925's Avatar
Any 1972 cheyenne door panels (black)? Thanks pm me
Ccc925 is offline
Old 08-03-2014, 01:49 PM   #762
Esetonni
Do you have any cabs?
Esetonni is offline
Old 08-03-2014, 08:14 PM   #763
pontiacpro
Do you have a front centerline for the steering and if so how much? Thanks
pontiacpro is offline
Old 08-04-2014, 04:00 PM   #764
GRADYS Performance
GRADYS Performance's Avatar
Do you have a throttle cable bracket for a mid 80s Q-jet with a TV cable hole for a 700R4 that bolts down with back carb bolts?
GRADYS Performance is offline
Old 08-04-2014, 06:18 PM   #765
pimpston65
pimpston65's Avatar
any horns lo and hi. t3 headlights. 3 section antenna.
pimpston65 is offline
Old 08-05-2014, 11:16 PM   #766
burb71
Active Member
A few parts that really need…
The bolt that holds the muffler assembly on to the A/C compressor
The Speaker to radio harness
A solid mast radio antenna
And last, the little 2 light bulb harness that go's to the A/C control ( I know it was a 2 bulb harness for 1968 not sure about other years.
Please let me know.
Thanks Steve
burb71 is offline
Old 08-09-2014, 01:03 PM   #767
tll74
"Junkyard Dog"
tll74's Avatar
Guys, sorry for the delay. I've been on vacation again and working 12-14 days so online and truck parts time has been hard to come by.
67JimmyMO, Jody, Yes. I have it off and I'm acid dipping as it has some surface rust. It could ship next week if your still up for it.
tjsblazer, I only have the bigger one. 14.00 shipped
Userone, I just bought a truck with one but I'm not sure if I'm going to part it yet. If i do I'll try to remember you for it.
JonnyC10, Yes I have a very nice pair. I acid dipped them which they didn't really need as they just some minor surface rust. 150.00 plus shipping. Shipping kinda spendy. LMK if the 150.00 is ok and I'll get a shipping cost.
Jake1971, I have the harness from the firewall to the bumper but nothing good from there to the sockets. I should have the armrest but I'll have to look to comfirm.
Ccc925, None that I'm willing to part with right now.
Esetonni, Yes but shippng to NC would kill the deal.
pontiacpro, 2wd draglink? If so what year and 1/2t or 3/4t? I have all of them.
GRADYS Performance, All the TH700 tv cable brackets as I recall all bolt down to the intake which I do have.
pimpston65, No HI note horns. Yes on the low. No T3's that I want to part with. Yes on antenna but couldn't get to pulling one for a couple weeks.
burb71, The speaker harness is soldered to the speaker. I would cut one off. 7.50 mailed. No antenna and nothing on the 2 bulb harness.
I will be gone on vacation again next Thursday through the following Wednesday. Thanks, Tom
tll74 is offline
Old 08-09-2014, 03:00 PM   #768
tjsblazer
tjsblazer's Avatar
Hey Tom, I've found a set in the mean time.
Thanks, Jeff.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 08-09-2014, 03:09 PM   #769
71 super
71 super's Avatar
Tom do you have a interior fuse box/ harness for a 67-68, the original one I have has some internal issues and I do not have lights or wipers. I prefer a 67 with idiot light dash, but will take what you have. Thanks harold
71 super is offline
Old 08-09-2014, 05:05 PM   #770
pontiacpro
1969 1/2 ton 2wd with manual steering. Price with shipping to 17331. Thanks
Old 08-10-2014, 09:14 AM   #771
67JimmyMO
67JimmyMO's Avatar
...67JimmyMO, Jody, Yes. I have it off and I'm acid dipping as it has some surface rust. It could ship next week if your still up for it...
Tom, yes I am still interested. If it was just surface rust on the carrier and the hardware is good that would be fine. Could you post a pic of it when you get a chance and let me know what the shipping is (65604)? Still no rush on my end...next week...next month...not a problem!
Old 08-10-2014, 11:58 AM   #772
tll74
"Junkyard Dog"
tll74's Avatar
Harold, I should have one from a 68 gauge/4sp truck I parted a year ago or so. I'll look for it Monday. If not I have atleast 5 complete 67-68 trucks that would have one but I couldn't get one out for at least 2 weeks. 65.00 plus 15.00 shipping for a very nice one.
25.00 plus 16.00 shipping. It is off and ready.
LOL...I'll post a pic when it is done.
Thanks, Tom
tll74 is offline
Old 08-10-2014, 12:30 PM   #773
Brave71
I'm looking for a nice set of vent glass shipped to 89015...thanks
Brave71 is offline
Old 09-03-2014, 06:58 PM   #774
rusted72'
rusted72''s Avatar
Tom-i received the alternator brackets today.
thank you
Old 09-03-2014, 08:43 PM   #775
pimpston65
pimpston65's Avatar
is it too soon to ask about the antenna?
Closed Thread
