Old 01-12-2004, 09:43 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Smooth Cowl
Does anyone have a good pic of a smooth cowl ... I need a good shot with the wiper's in the pic.. Thank's Luke.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 01-12-2004, 09:45 PM   #2
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
ill scan my truckin mag. "Color a money" has a smooth cowl.
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 01-12-2004, 09:46 PM   #3
Blue Beard
Blue Beard's Avatar
Seems like there was a thread on the smooth cowls.............see if I can find it...
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-12-2004, 10:21 PM   #4
724x4a/cchevy
Heres the only smooth cowl that ive ever seen.
My LED Website
I also do LED:
-Third Brake/Cargo
Norwood Survivor
Old 01-12-2004, 11:21 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
Thank you!!!!
MEMBER #6377
Project "7DEUCE"
Old 01-12-2004, 11:31 PM   #6
Smooth68
Smooth68's Avatar
Well there's at least one more.....
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
Old 01-12-2004, 11:39 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
Sweet the body shop guy was kinda fuzzy on what I wanted so I figurewd pic's were the best way to confirm what I want or I may just do it my self...
MEMBER #6377
Project "7DEUCE"
Old 01-13-2004, 12:39 AM   #8
71Rat
ran out of money
71Rat's Avatar
i don't mean to hi jack the thread or anything but i was always wondering how your vents worked on the inside of the cab with a smooth cowl? isn't all the air that comes through them come from the cowl? maybe i am missing something. if anyone could share with me how it works, thank you
Rat
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 01-13-2004, 01:03 AM   #9
Smooth68
Smooth68's Avatar
Vents?!?! We don't need no stink'n vents.....no seriously I have removed the vents and I am using the driver side vent cavity to hold my fuse panel - they will be totally covered later.
Smooth68's Web Site
Old 01-13-2004, 01:17 AM   #10
saulgoode
saulgoode's Avatar
71Rat
hope this helps it's a thread i started should answer your question about vents. Seems to me that smoothing the cowl would help eliminate leaves and junk from getting down in kick pannel and causing rust just a thought.
Cody
saulgoode is offline   Reply With Quote
Old 01-13-2004, 01:25 AM   #11
FRENCHBLUE72
PROJECT 7DEUCE
Hey smooth that's great web site ya got thank's..
MEMBER #6377
Project "7DEUCE"
Old 01-13-2004, 04:10 AM   #12
Rooster's 67
Rooster's 67's Avatar
has anyone done this modification and what did they use to do it? or known/seen it done in more detail.
I am thinking of doing this to mine and using 18 or 20ga steel and cutting it to fit the slotted area and the welding it in place, and then of course finishing it out with metal work and then filler.
Or did they cut individual fillers for each slot and weld, or use fiberglass(seems it would crack out from the weird palce to work it) If any one knows thanks.
If not I am going to use 20ga and cut it to cover the whole area and work it smooth.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 01-13-2004, 12:04 PM   #13
ScottH
ScottH's Avatar
I'd also like to know about the vents. Would installing a smooth cowl prevent air from getting to the vents (my only a/c)?
Thanks.
ScottH is offline   Reply With Quote
Old 01-13-2004, 02:05 PM   #14
saulgoode
saulgoode's Avatar
Oops forgot to post link to thread. Should answer questions about vents and ac.
http://67-72chevytrucks.com/vboard/s...highlight=cowl
Old 01-13-2004, 02:32 PM   #15
Rooster's 67
if you shave the vents it will affect the a/c and heat due to the fact that in the fresh air mode it pulls air from the cowl area and the kick vents are fed by that area also.
but the fresh air aintake for the a/c heat can be moved to another area like the side of the cowl inside the fender but you may get engine heat and fumes too
