Old 06-06-2014, 01:00 PM   #1926
Frizzle Fry
Frizzle Fry's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Damn, it's getting nasty up in here.
work has taken over...! Here are some leading pics:
Frizzle Fry is offline   Reply With Quote
Old 06-06-2014, 01:38 PM   #1927
ajgriffin
ajgriffin's Avatar
That looks amazing! How does the process work? How's the solder get applied and smoothed?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 06-06-2014, 01:42 PM   #1928
Frizzle Fry
Here you go -->http://youtu.be/gX5YjrsD_Pg
Old 06-06-2014, 03:50 PM   #1929
ajgriffin
ajgriffin's Avatar
This guy is awesome. I love the product demo's he does. Was this your first time using lead/solder?
Old 06-06-2014, 04:07 PM   #1930
watahyahknow
watahyahknow's Avatar
lead .... at least in the quantities hes aplying it is better than bondo , it protects the metal underneat from rusting unlike bondo thats slightly porious and can hold water in under the paint
the only reason bondo took over is because its eazier to work with
when lead is aplied too thick it will crack over time , the term leadsleds comes from the leadwork moulding the creators used before painting
im alergic to epoxy (main ingredient in bondo) and i would love to learn to work with lead that way
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 06-06-2014, 04:22 PM   #1931
mcbassin
Still Learning
mcbassin's Avatar
Looking good Frizz
Old 06-07-2014, 02:01 AM   #1932
Frizzle Fry
Yeh, first time leading. Went pretty smooth. I could have used more (any) solder paste on the wooden paddles. I'll be doing more leading soon. Been working on the front fender to rocker seams Thanks for the continued interest guys.
Old 07-21-2014, 11:14 PM   #1933
Frizzle Fry
On vacation this week. Guess where I'm spending it...
Old 07-21-2014, 11:33 PM   #1934
VA72C10
VA72C10
VA72C10's Avatar
working on the tahoe???
Old 07-22-2014, 11:35 AM   #1935
1Bad 37
1Bad 37's Avatar
This gon' be good...
1Bad 37 is offline   Reply With Quote
Old 07-22-2014, 12:18 PM   #1936
Frizzle Fry
Yeh, as you can see, tubby's been getting a little drywall action
Let's hope. Here we go..!
The only two cancer spots found on the car during blasting were the lower/rear front fenders. I cut them out while at the blaster's to allow the inner structures to be cleaned.
The panel alignment was pretty bad here. Since the fenders are welded on anyway, they might as well be welded here too
Other side:
I hit the inner structure with this eastwood product before closing it up.
Did the inside of a bunch of other areas while I was at it:
Close it up.
Not perfect metal finished because it will need a little lead-free.
Old 07-22-2014, 12:21 PM   #1937
Frizzle Fry
More detail work:
Old 07-22-2014, 12:28 PM   #1938
Frizzle Fry
Panel misalignment everywhere ...or is it just me..?
This side was worse.
Drastic measures required.
Old 07-22-2014, 12:48 PM   #1939
Frizzle Fry
These cars had a tendency to rust in the upper and lower rear of the front fenders. Luckily mine was only afflicted with the lower/rear variant. This vulnerability is due to the lack of inner fender liners - the insides of the fenders were open to the world of whatever the tires decided to throw at them.
I decided to make removable ABS plastic liners to close the chasm. I started with a pair from an 80's Audi, then cut, heated, molded and trimmed them to fit. They both have a notch near the front I'll have to cover, and they are by no means show-quality, but they'll serve their purpose well.
They are mounted with rivets (clecos for now) and tabs.
1st side:
Template from 1st to make 2nd:
2nd:
Double rivets in first:
I plan to add one more bracket to that front corner.
Old 07-22-2014, 01:14 PM   #1940
mcbassin
Still Learning
mcbassin's Avatar
You sure have a way with metal! I'm kinda envious of you Cleco collection too.
Keep the excellent pictures coming. Sitting here in awe as always.....
Old 07-22-2014, 03:06 PM   #1941
shearjs
shearjs's Avatar
Incredible work! I'm in amazement every time you make a new post.
shearjs is offline   Reply With Quote
Old 07-22-2014, 08:18 PM   #1942
MP&C
MP&C's Avatar
FF, I attended a metal shaping demo a couple years back where a guy showed leading using an old (non-powered) soldering iron instead of a wooden paddle. He said he preferred the soldering iron (heated with the torch), because it held some of the heat it made for an easier time of manipulating the "lead" on the panel.
Not sure where one would get such a tool, but now everyone knows to look out at your local yard sales for them!
Robert
MP&C is offline   Reply With Quote
Old 07-22-2014, 11:13 PM   #1943
watahyahknow
i bet it wouldnt be that hard to make sumtin like that out of copper rod , like the stuff they use for lichtning conductors or at an electric railroad
kindah hammer one end intoo an arrowhead then hammer the sides down to one side and use a file to get that sde smooth and flat
bend the rod intoo a lazy s
stick the other end of the rod in a wooden handle and youre done , dont even need to heat the copper anly afterward to get it a bit softer again as it will workharden
it prolly be eazier then using wood as you can make it to only melt the top part of the lead mostly
Old 07-23-2014, 12:57 AM   #1944
Frizzle Fry
Looks like it would be useful when adding more lead after the first round. I can tell you from today's experience that it's very tricky to pull off without ruining what's already there. I actually ended up starting over completely at one point today. I need to research more about tools and supplies...
Also did a lot of little boring jobs not worth pictures.
It'll still need some glazing, but it's better than all plastic I guess. Glad I started with an "easy" spot By the way, the reason the solder looks greyish in the finished pic is because I hit the whole area with Ospho when done and the phosphoric acid greys it.
Old 07-23-2014, 09:06 AM   #1945
ERASER5
ERASER5's Avatar
"Also did a lot of little boring jobs not worth pictures"
Somehow, I get the feeling that your boring jobs would still spark interest for the rest of us. So now I also need to learn leading...
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 07-23-2014, 09:30 AM   #1946
67ChevyRedneck
67ChevyRedneck's Avatar
Frizzle, your ADD is way worse than mine, I would have let that crap go
Amazing as usual.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-23-2014, 10:11 AM   #1947
thor
thor's Avatar
Is (lead-free) leading easier and/or faster than hitting the low spots with the MIG again? Or are you just learning a new way of doing things?
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 07-23-2014, 02:11 PM   #1948
Frizzle Fry
Filling and re-dressing pinholes, tightened up the master cylinder hole (the willwood is slightly smaller than the honda). And I've been working on the trans tunnel/shifter area which will be posted when complete.
The lead(free) has its place. I think it's worth learning.
I do have ADD pretty bad sometimes, but I think in this case it would be OCD
One of the biggest problems I face with metal finishing is grinding too thin. When you repeat welding and grinding this is the risk. And if you go for the fully metal-finished appearance like I did on that fender section it's both time consuming and at risk of thin spots. I was very aware and carful of this, but I have gone too thin elsewhere.
If you've noticed the crescent shaped cut-out in one of the inner fender wells in previous pics, that area was too thin so I cut it out.
With these seams there's a bit of a flat spot or even slight depression at the joint. Lead allows you to build an area a lot more than you would want to do with a mig and instead of being a risk of thin spots your are actually making it stronger.
Old 07-28-2014, 01:08 PM   #1949
thor
thor's Avatar
Good info. Thx for the explanation. You make the metal look so smoove!
Old 07-28-2014, 09:54 PM   #1950
Frizzle Fry
Re-reading your question I should add that yes, leaning a new way of doing things is always a driver for me. The technical benefits are all justification for pursuing that kick in the discovery
