Old 07-21-2014, 12:11 AM   #1
c10 custom
1975 chev rust issue under windshield
Hi everybody i am looking at a 1975 chev shortbox truck and the body looks good except for 2 quarter size rust holes under the front windshield i was
wondering is this something that can be fixed fairly reasonably i appreciate the replys thank you
c10 custom is offline   Reply With Quote
Old 07-21-2014, 04:25 AM   #2
donut
donut's Avatar
Re: 1975 chev rust issue under windshield
Pics may help, also what's your skill set?
Odds are it's a cut/patch deal (welding may be required) removal of the windshield may help. Expect the rust to extend further than what can be seen.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 07-22-2014, 12:13 PM   #3
cadillac_al
I work on rusty Squares all the time and never had one rusted by the windshield. If it has rust up there then I would worry that the floor boards and rockers and cab mounts might be shot. I would look it over real close before buying it.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 07-22-2014, 02:08 PM   #4
Your41Plague12
Your41Plague12's Avatar
It's common for water to get in due to a faulty windshield gasket, through the cargo light if the truck has one, or also through the clearance lights on the roof. I know this because my 83 was rotted under the windshield, at both corners of the back window, a lot of the firewall, both floor pans, the cab braces and supports, rockers, cab corners, etc. There really wasn't much left. It's repairable, but I'd look into finding a new cab. Typically if it's rusted there, you have much worse problems that aren't easily visible.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 07-22-2014, 06:50 PM   #5
donut
donut's Avatar
My '73 had some good size rust holes under the windshield gasket. (old plow truck with no floorboards...) 30+ years of Maine winters took their toll.
Obvious places to look are the cab corners, inner/outer rockers. These may have already been repaired at some point.
Even my '86, which is a southern truck, has holes in the cab corners and the cowl pinch weld to the firewall. The cowl was neglect on the former owners, imo.
Old 07-22-2014, 09:15 PM   #6
50seven
50seven's Avatar
I've put patches in front lower windshield/gasket areas and yeah might as well plan on at least 3 times the size of what originally looks like needs to be fixed. There is supposed to be a drain hole under each side of the windshield rubber gasket (about an 1/8" diameter). This hole might get plugged, maybe salt gets trapped, possibly paint scratched from a previous window install and that area can rust.
Depending on how long the area is leaking it can rust right into the dash around the VIN.
Post some pictures.
50seven is offline   Reply With Quote
