Old 04-30-2014, 04:43 PM   #126
1963c-10
1963c-10's Avatar
Re: Big Block Build is what I'm calling mine. New pics inside
Originally Posted by Chevy Fleetside View Post
For the motor mounts I trimmed back about 1/2 inch. I used the rear holes but cut the firewall. As for the headers... I just put them in and made some marks on where to trim the frame. I think I just used a grinder. It wasn't very much if I can remember.
OK ,thanks. I'm using the CPP tubular mounts, so I won't have to trim the frame for them, but I will have to drill a hole in the crossmember for the lower bolt to go through. I guess I'll set the block in and see where it needs trimmed prior to doing any trimming. Was trying to save some time and pre trim, but with all the big block swaps I've seen everyone has different mounts, mounting locations, headers...etc. So safe bet will be to trim where I need to once the engines in. I've got a grinder so that's no problem there. I have an air nibbler too that I though might work, but I like the grinder better.
Fixing to drop a 1st gen 348 big block into the fleetside too....check it out if you haven't already. Will be a fun build.
I'm sure more questions will pop up as I go on with it. Thanks again.
1964 Short bed trailer
Old 04-30-2014, 11:59 PM   #127
Chevy Fleetside
Chevy Fleetside's Avatar
I put my engine and trans in and out of my truck probably 10 times before I painted it. It was really nice to stick it back in the last time and just be able to bolt it up and leave it...
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 05-01-2014, 08:25 AM   #128
1963c-10
1963c-10's Avatar
I hear you there.....I've already moved it a half dozen times and it hasn't made it into the frame rails yet. Was musical engines around here trying to juggle the 230, 348 and the 427around in a small space.
Old 05-01-2014, 09:07 AM   #129
kieth
kieth's Avatar
Originally Posted by AcampoDave View Post
Did you get the Tank's inc universal installed yet? 'm curious to see how you bolted up the straps. I started on mine today.
We started by welding nuts to the frame so we could bolt the tank in before the straps went in to place..
Just click on the individual thumbnails to take you thru the process:
http://kieth.smugmug.com/Trucks/66-GMC/i-svjGkRJ
We then modified the straps so they would stay attached to the rear crossmember and be removable from the front crossmember.....just click on the thumbnails for next picture.....Kieth
http://kieth.smugmug.com/Trucks/66-GMC/i-GHLg7T2
kieth is offline   Reply With Quote
Old 05-01-2014, 05:52 PM   #130
Chevy Fleetside
The Tanks inc tank is differnt then the one you have. I have one of those tanks in my blue truck and I ran the straps from left to right on the frame.
Old 05-01-2014, 08:48 PM   #131
TJ's Chevy
TJ's Chevy's Avatar
Looking good! Neat to see it out again!
Old 05-03-2014, 03:14 PM   #132
Chevy Fleetside
They both finally stood still for a photo... its like a truck get together in front of my house.
Old 05-05-2014, 09:43 AM   #133
earl84
Very nice, Chevy Fleetside. Great to get it on the road and start building confidence with some longer drives.
Questions for you, what fan and shroud combination did you go with? I am assuming your serpentine system was the stock setup from the BB, right? Any issues with getting too hot?
earl84 is offline   Reply With Quote
Old 05-05-2014, 10:38 AM   #134
Chevy Fleetside
I have no fan shroud right now. I also don't have a temp gauge hooked up and that is the reason I don't go very far. I have some gauges coming and will know how the heat is doing. I am running a stock fan with clutch.
Old 05-06-2014, 09:39 AM   #135
earl84
Thanks for the reply. I ask because I am in the final stages of installing a 454 in mine. Initial measurements said that the stock fan wasn't going to fit, but I was holding the radiator support in place and it was difficult at best. So I ordered up a Mark VIII fan after doing research, but I don't think that is gonna fit. So I grabbed an old fan and clutch off a 350 and it fits fine, but close. I did some searching and found measurements for a Hayden severe duty fan clutch and fan, should work fine. Gonna have to build a shroud. It is such a big deal cuz I fitted a SBC serpentine system on and had to use a long water pump to do it. I just like to make things super hard on myself on this very first attempt at doing a restomod on anything, you know. Why make it easy, ha?
Old 05-11-2014, 10:55 AM   #136
Chevy Fleetside
Been working on my gauge panel. I am leaving for Yosemite today for a week so I will get back to it when I get back.. Made that out of a piece of 3/8" oak and stained it.
Old 05-11-2014, 11:11 AM   #137
RockTonka
RockTonka's Avatar
That looks nice! Are you going to have any other oak accents in the truck?
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 05-11-2014, 02:35 PM   #138
Chevy Fleetside
not sure. I just had this wood laying around. I think some oak door pulls would work
Old 06-14-2014, 02:12 PM   #139
Chevy Fleetside
all lit up...
Old 06-15-2014, 08:48 PM   #140
MisterC
MisterC's Avatar
That looks fantastic! Well played.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 06-17-2014, 01:19 PM   #141
cff
Active Member
Hi. I don't know if I missed it , but where did you get your motor mounts from? Thanks, Ron.
cff is offline   Reply With Quote
Old 06-18-2014, 01:41 AM   #142
Chevy Fleetside
truckandcarshop.com ..
Old 07-02-2014, 08:30 PM   #143
Chevy Fleetside
just adding a few pictures of some progress.
Old 07-23-2014, 11:33 AM   #144
Chevy Fleetside
I found this picture of my truck on the internet and just thought I would post it in my thread. This is at the Drive In movies for the Hot San Jose Nights Car Show. I really need to get going on the bed.
Old 07-23-2014, 01:03 PM   #145
supercharged
supercharged's Avatar
Here is where I am now. Still need to hook up Brake lines and a few other small things. Just some update pictures.
Man-o-man that is one sweet set-up.
Supercharged Scottsman
Scottish by birth, American by law,
Texan by the grace of God.
“To avoid criticism say nothing, do nothing, be nothing.”
― Aristotle
supercharged is offline   Reply With Quote
Old 12-30-2014, 12:49 PM   #146
Chevy Fleetside
rollin down the freeway. Thanks for the Freeway shot Slow Build.
Old 12-30-2014, 01:29 PM   #147
ol_skool_chevy
ol_skool_chevy's Avatar
Very nice
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 01-21-2015, 02:58 PM   #148
Chevy Fleetside
Today I put a new battery in my truck. Summit said i bought the other battery in Oct 2013. Without jumping through hoops they sent me a new battery becuase I said it wasn't holding a charge. Battery wasn't strong enough to start the truck after 3 days and that was with a battery cut off switch.
Not to mention I called on Monday and the battery was here Tuesday. I wanted my money back but they can't do that so I am stuck with the Optima Battery for now. We will see how long this one lasts.
Old 04-02-2015, 10:01 PM   #149
Chevy Fleetside
Before and After.. More to come
Old 05-24-2015, 11:28 AM   #150
Chevy Fleetside
I just looked through my thread. I notice I never said thanks for the compliments. I feel like a dork right now so I am saying thanks now.
Better late then never I guess.
The truck is running really good right now. I noticed the more I drive it the better it gets.
Thanks again.
