01-03-2014, 04:21 PM | #26 | |
Re: LED / HID offroad light positioning
Well you are partially right about the reflector, but it depends on the light. Old school lights always had the same reflector but the different lense changed the pattern. Just look at the Halogen Rallye 4000 from Hella. The pencil is a clear lense, same reflector with some structure in the lense is the euro beam and with a lot of structure it turns into the cornering beam. the reflector is the exact same. (i had the apart, so I know). On the newer lights with free form reflectors, all lenses are clear, so the difference is in the shape of the reflector. On your old school daylighters, the lense makes the diferent pattern. Here are two links to the "flood daylighter" http://thumbs4.ebaystatic.com/d/l225...KKY2Fn52iw.jpg http://www.autoaccessoriesgarage.com.../2701_1_md.jpg this is the driving lense (between spot and flood) http://www.demon-tweeks.co.uk/oncirr..._spotlight.jpg https://www.driveout.co.za/sites/def..._Lights_17.jpg and this is what you seem to have, the spot or pencil lense https://www.fortec4x4.com/images/W/K...r-in-Black.jpg Hope this helps.
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104 68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441 |
01-05-2014, 06:56 AM | #27 |
Any more opinions on the different setups?
01-05-2014, 10:25 AM | #28 |
Another Day, Another Dollar
Here's what I'm running. Not quite as fancy but with 100w bulbs its more than bright enough for cruising logging roads at night.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
01-05-2014, 01:00 PM | #29 | |
So you did swap the cab to a 84 cab but retained the 78 front clip... did that just bolt up? I need to replace my cab and want to find a better one and swap it out, just curious on how well that worked with a newer 81-up cab.... thanks..
01-05-2014, 01:23 PM | #30 |
There were some minor differences but if you can handle a little bit of problem solving its not a big deal. I used my '78 wiring harness. I'm on a plane right now but I'll check your renderings later.
01-05-2014, 01:36 PM | #31 |
#4. But I think the light bar on there now looks the best
01-05-2014, 03:20 PM | #32 | |
My truck is all rewired anyways, with a painless performence harness. That is universal fit anyways. Thanks! Well, the light bar (LED) looks great but doesnīt give me enough distance, that is why I need some kind of HID light in adition at least, to shine down the trail or road further. Therefore all these renderings! #4 is counted! Thanks again!
01-09-2014, 11:47 PM | #33 |
78K & 79C Jimmys
I'd go #8 ....I had big off roaders in front of my burb,lots of deer where i go camp
i bought 6 only used 4 , I wanted to put them on the roof but saw a roof get ripped open,went bumper when i get time i'm gona put them on the jimmy
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
01-10-2014, 07:22 PM | #34 |
Thanks for your input! Are all 4 lights spot/long distance?
01-11-2014, 12:07 AM | #35 |
78K & 79C Jimmys
yup,huge difference,i used two switches,inside and outside wired together,
so i'd see far or wide,or both,to do it now i'd use relays for sure
01-11-2014, 03:55 PM | #36 |
I agree, you can never have enough lights at night! Makes it so much nicer when you can clearly see where you are going!
03-05-2014, 06:56 AM | #37 |
Any more opinions on what you guys like best out of all the options?
Thanks!
05-02-2014, 03:12 PM | #38 |
I posted this in my build thread too, but this is some new renderings I did....
let me know what you think of this set up.... or with black trim rings
07-23-2014, 04:18 PM | #39 |
So decision is made: the OnX bar will be swiched to amber for bad weather and dust, the squadrons will stay the way they are, and Iīll add two Rallye 4000 compact HIDīs to the bumper and then mount 5 of the big rallye 4000 HIDīs on a roll bar or headache rack above the roof. That should be plenty of light!
