soft top Questions
Just looking for info on soft tops,how many kinds there are,cost,do some leak less than others. My blazer came with a top i don't know what kind. It has a couple of holes and leaks at the seams, It needs to be repaired or replaced
which way is cheaper. |
bumped
SKINNY TIRES RULE!
I'm only aware of 2 manufactures - Specialty Top Co and Bestop. Specialty Top Co makes two types - Fastrack and Button Down. I don't know too much about the Bestop brand. Kayline used to make tops but they went out of business and Specialty Top Co uses their patterns. I have an old Kayline top on my '69 and it works pretty well. There are a few leaks around the door windows, but nothing more than a hard top does. The zippers in the back are a weak point and mine are broken. I recently bought a Specialty Top Co Fastrack top for my '72 but I haven't had a chance to install it. They run around $650 and the button down top is a little less.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
BESTOP has 2 different styles.....costing $650 to $700. I've had 3 BESTOPS and one KAYLINE and they both were about the same in quality,fit and lasting about the same length of time before rips and tears started appearing.
I have a STC fasttrack. I really think the make a great quality top. I you decide you can't salvage yours Stc has several colors and styles to choose from. They are about $600.00 or so
i'd love to see closer if you have pics vlad
I do have more pics. Only problem is I can't post them on this site because of file size restictions . They were taken at a large resolution and i don't know how how to reduce them. If you want to give me your email address I would be happy to email you what ever angles you want to see.
![]() Join Date: Feb 2000
I will PM you, you can send them to me and I will resize and post them for you if you want.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Thanks alot if you could do that for me. do you want a broad overview of the top? Or do you want specific details such as the frame's, mounting harware and acces.Let me know I can take get you what ever details you like.
how many pics do you have, pm sent
Edit: HEre ya go well i messed up the rest you e-mailed me. Deleted them before i realized they didnt save as a proper file. If you feel like re-sending some i'll get'm up. Last edited by 71 Blazer CST man; 09-16-2004 at 12:35 AM. |
Don't mean to interrupt, but that is an AWESOME looking JIMMY!!!!!!!!!
![]() Vlad, please post specs! Lift, tires, motor, trans etc etc etc. ![]() sorry guys and gals, don't see too many jimmys.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
Here are the other pics. Awesome K5!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 09-16-2004 at 09:54 AM. |
Big Big thanks goes out to YUKON JACK and BLAZER CST MAN for helping me Post those pics. I truly am tech.challenged.
The Rig has; 350 w/all edelbrock accessories mated to a 350 trans, Np205 ,Dana44/12bolt w/410's and eton lockers. super lift 4" soft ride w/Rs5000 shocks,and a 3" body lift. STC Fasttrac top, Valspar (majestic blue) paint. Gray tweed int. All sitting on 36x14.5X15 super swamper TSL radials mounted on M/T Classic 2's |
Vlad, how did you get your jimmy to sit level? I assume you put 4 inch springs in the rear also. Did you need to tweak the rear to get it to look level with the front? Awsome man!
![]() How about including the JIMMY in the "how many 4 wheel drive blazers do we have" thread. ![]()
#15 |
Well with the way the bodyline on the rear quarter panel seems to sweep downward,puting level springs front and rear still gave it the appearance of dragging its ass. So I took the rear springs to my local spring shop and had them rearched to add one more inch of height.Before when I set a bubble level on top of the bed rail it was plumb. Now the level will bubble up toward the rear of the truck slightly.
#16 |
Red Headed Step Child
Vlad. Do you have any pics of the top folded back? I'd like to see how it looks when it's down Thanks.. Stinger
"Dinner, the perfect break between work and drunk" -Homer Simpson |
#17 |
Sorry I don't have any photos of the top down,as i have never had it down. I think if i ever decided to go "topless" I figure I would just remove the top and bows completely,for a more streamlined look.
#18 |
Goodbye Darlin'
Whoa, that's nice!
1971 Blazer CST SOLD! |
#19 | |
The LuvShack Garage
#20 |
Thanks for the info guys. My top must be a old k-line it is a button style and has had a few repairs. Should replace it with the one vlad has it looks great.
i'll start saving.Hey yukon i had the same problem as vlad with my pics can you help me out. |
#21 |
![]() Join Date: Jul 2010
Re: soft top Questions
Resurrecting an old thread here. Vlad, any chance you could post some close-up pics of the front section of the soft top frame around the doors and windshield? I just got a Fasttrac but no instructions came with it. So I'm having a hard time figuring out how some parts of it go together.
#22 |
these guys made a top too http://www.offroaddesign.com/catalog/softtops.htm
#23 | |
SKINNY TIRES RULE!
#24 |
I had the top on my first generation blazer and it's garbage!! Quarter size holes in the top and bottom of the side glass. You had to wrestle with it to get it to snap tight and with zero miles on it the seam for the window and top slipt apart.
I called softtopper multiple times and left messages, not once did they call me back.
///Relaxed Atmosphere |
#25 | |
![]() Join Date: Apr 2007
