Old 07-24-2014, 09:03 PM   #1
Blackpony
Blackpony's Avatar
Re: under bed tank options
Originally Posted by Nola67 View Post
Cool work br3w city. Does the fuel line have potential getting caught on something going down the road or is that just the pic?
Black pony, whats the measuments on the tank? Price? Any ground clearance concerns? Seems like a decent alternative to a 800$ aftermarket tank..
The tank is huge, its 31 gallons. I just ordered the tank and hanger assembly from ebay. Got the part numbers off oreillys website and put them in the search. I believe all said and done I have around $250 in it all. The fuel pump i actually got for free. I work at a performance shop and we had a bunch of factory 5.0 mustang fuel pumps laying around so i cut out the pump itself and installed it. Those cars run around 55 lbs of fuel pressure so it should be fine. I have also made over 600 rwhp using the stock pump without a boost a pump so I will be fine there. I will try and get a few more pictures, but with the way I fabbed my hitch it barely fits but it fits. Also one thing to note is the filler neck will need to be relocated. Lastly ground clearance should be around 10-11 inches at the lowest point. The tank has a notch at the rear that helps with clearance also. Hope this helps, my swap is not a simple bolt it in, some fab work will be needed, but all said and done it will be at least half the price as most other aftermarket tanks.
Blackpony is offline   Reply With Quote
