Old 07-26-2014, 01:25 AM   #701
sqrlnts
Re: 1949 Chevy 3600 into a daily driver
Originally Posted by Coach529 View Post
I am actually hoping to find some small rounds ones.
Those will be a little harder to pee on and be careful, objects in mirror are closer than they appear.....
sqrlnts is offline   Reply With Quote
Old 07-27-2014, 06:05 PM   #702
NEWFISHER
NEWFISHER's Avatar
Bawahahaha!
Its always fun to come back from camping and check in at the water cooler.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 07-27-2014, 10:11 PM   #703
Coach529
Coach529's Avatar
So I have some miles on the old guy now. Runs like a champ.
I think I need another set of wheels with some cheap tires on them. The wide whites are taking a beating!! I taught my oldest son the better points of a smokey burnout today...........turns out my 3.43 rear end is limited slip.
Next step is going through the suspension. Front springs are sagging and I am sure all the shackles and bolts are shot. Lots of rattles and rough ride. Probably going to lose some of the low stance, but it will be worth it for a little better ride.
Then start tracking down rattles and cab noise.......
I will also be looking for a little better gearing for the highway. I do not have a tach, but I am guessing I am pulling 3K at 65 right now. Would like to drop that a bit.
Speedo is off about 15mph at 65mph. Need to fix that........
If I could do the whole conversion again about all I would do differently is change from hugger headers to ram horns to make fitment a bit easier. Other than that......the whole experience was pretty painless!!
Thanks for all the input......made it all pretty easy for a newbie!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 07-27-2014, 10:29 PM   #704
99 to Life
99 to Life's Avatar
nice glad your running it. I'v been putting more miles on my truck than ever this year, made it a point to. but....its rained so much I keep her in alot too.
I have an nv3500 5speed with 3.42 gears and I run about 2100-2200 rpm at about 65mph. I just picked up my 5th one of those transmissions, hard to find but so nice to have and runs good. Oh and I have the G78 bias whitewalls on 14" rim. its about 26" tall I think.
new components will def make it sit higher, my friend did up his leafs and shackles in his 54' belair, he gained like an inch.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 07-28-2014, 08:38 AM   #705
Coach529
Coach529's Avatar
After driving with an auto, I had no desire to go back to a manual. Not for the typical driving I am doing anyway.
I will either change the rear end or upgrade to a 700R4.
1949 Chevy 3600
Old 07-28-2014, 09:56 AM   #706
NEWFISHER
NEWFISHER's Avatar
700r4 for the win!
Finding out the rear is limited slip without pulling the cover...priceless
GOD BLESS AMERICA!
Old 07-28-2014, 09:59 AM   #707
Coach529
Coach529's Avatar
Originally Posted by NEWFISHER View Post
700r4 for the win!
Needless to say, the parallel long dark black marks on the asphalt were impressive!!
1949 Chevy 3600
Old 07-29-2014, 05:40 PM   #708
Coach529
Coach529's Avatar
Walked right past my company truck and hoped in Henry for my 15 mile commute to work.
Henry's step brother "Gene" was here too!!
Gene is a baddass '49 GMC owned by a coworker. Sweet build done about the same time as Henry!!
383 stroker, tubed with narrowed 9", over the frame headers..........dream build list!!
Cool thing is "Gene" is also a Family truck It was Casey's Grampa's truck.
Both trucks live 4 blocks apart!!
1949 Chevy 3600
Old 07-29-2014, 10:15 PM   #709
99 to Life
99 to Life's Avatar
thats some darn cool history and patina there. I wish I could get a hold of that, a family heirloom of any sort. So by the looks, gene runs down the track. any info on that? was planning on taking my 49' I'm working on to the strip once its done, just to see what she'll do.
Old 07-29-2014, 10:52 PM   #710
Coach529
Coach529's Avatar
It is primarily a cruiser........not sure if it has even made an official trip down the strip.
1949 Chevy 3600
Old 07-30-2014, 11:07 AM   #711
dubie
dubie's Avatar
Nice to see you've got Henry back together and are now out enjoying it. I know once we put our 56 back together there were ALOT of squeaks, chirps. clunks etc in the cab. Once you change out your old spring, you'll notice a big difference. I went with mono leafs but if I had to do it all over, I'd get some Posie super sliders. You lose about 3/4" of ride height but you can run a taller tire and you're going to want all the side wall you can get.
Are you running the stock seat? I find the spring in the seat base are an added suspension perk in a dropped axle truck
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 07-30-2014, 11:10 AM   #712
Coach529
Coach529's Avatar
Yes, running a stock seat.
1949 Chevy 3600
Old 08-08-2014, 10:35 PM   #713
Coach529
Coach529's Avatar
Nothing new to post.
Got the timing dialed. Somehow it was very retarded. Set perfect now. Runs even better now. Carb is dialed in as well.
Lost of little stuff to do, but I am enjoying driving it to much. If I go more than a couple days without at least a short cruise I get crabby!!
1949 Chevy 3600
Old 08-10-2014, 07:25 PM   #714
NEWFISHER
NEWFISHER's Avatar
Ah the good life!
GOD BLESS AMERICA!
Old 08-10-2014, 07:47 PM   #715
Coach529
Coach529's Avatar
Ah the good life!
Exactly!!
1949 Chevy 3600
Old 10-12-2014, 03:37 PM   #716
49Fireman
Coach. I'm sure this was covered long ago during the original build but what center caps and lugs are you using on your cragars? I like yours better than the spider caps and the spiders would cost around $160
49Fireman is offline   Reply With Quote
Old 10-12-2014, 06:54 PM   #717
Coach529
Coach529's Avatar
The bullet center caps were Cragar brand, I think I got them from Jeg's for less than $10 each. The bullet lug nuts came from Jeg's as well.
1949 Chevy 3600
Old 10-12-2014, 07:12 PM   #718
49Fireman
Perfect. Thanks Coach
Old 10-14-2014, 11:59 AM   #719
Coach529
Coach529's Avatar
No problem!!
1949 Chevy 3600
Old 12-28-2014, 11:05 PM   #720
Coach529
Coach529's Avatar
Getting the itch to do some wrenching on Henry.
Hunting season is almost over......so I have some parts on order.
I ordered a cam to wake up the SBC a little. I ordered a Xtreme Energy XE268H.
I also order a 12 circuit EZ wiring harness.
Let the fun begin!!
1949 Chevy 3600
Old 12-28-2014, 11:22 PM   #721
solidaxel
solidaxel's Avatar
[QUOTE=Coach529;6975259]Getting the itch to do some wrenching on Henry.
Let the fun begin!![/QUOTE
Good choice on the cam, you will like the 268*
The EZ kit has what you need
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-28-2014, 11:40 PM   #722
Coach529
Coach529's Avatar
I will admit I am 100% looking for better sound out of the SBC.....already makes more HP than I need.
1949 Chevy 3600
Old 01-02-2015, 09:21 PM   #723
Blanco
good build lot to learn here
Blanco is offline   Reply With Quote
Old 01-06-2015, 12:49 PM   #724
Coach529
Coach529's Avatar
Slowly tinkering as I have time.............there is never enough time.
Cam, sprockets and chain are here.
I started "Finally" putting in my passenger side Altman EZ latch kit. It is sad I put the drivers side in almost 2 years ago.
My 12 circuit EZ wiring harness came in as well!!
1949 Chevy 3600
Old 01-09-2015, 08:39 AM   #725
1948GMC
1948GMC's Avatar
I love your build man might have said it on hamb but I like it here better
1948GMC is offline   Reply With Quote
