4x4 conversion
Afternoon Gents, I own a 70 GMC 1500 2WD, and i would really like to put an axle under the front and turn it into a 4x4, I know there's more to it then just throwing an axle under there, but does anyone know of a conversion kit? how about a good build thread showing how it was done?
Thanks- Eric
'06 2500 HD 4x4. manual transfer case, crank windows. '88 V10 Suburban 4x4,"The Pig Rig" L05, 700r4, NP208, 4x4 beater camper fun truck project. My trucks don't leak oil, they mark their territory. |
![]() Join Date: Mar 2000
Re: 4x4 conversion
I've seen 73-87 front 4x4 front suspension, tranny and transfer case grafted onto a 2wd coil spring 67-72. It made a nice little 4x4 for non extreme off roading. It seemed a little strange at first but it all worked.
Saskatoon, Saskatchewan Canada |
Re: 4x4 conversion
Might be easier to just use a 73-87 4x4 frame and just swap body over. You will have all components and disc brakes.
Re: 4x4 conversion
I'd rather retain the stock frame rails if possible. got a link?
Newbee
Re: 4x4 conversion
I converted mine. Check out my build thread.
Re: 4x4 conversion
if you have any more pictures of the front axle swap in hiding somewhere, I'd love to see them! good looking truck, and great job on the swap!
Newbee
Re: 4x4 conversion
This one shows the front brackets, and the e-brake dimple that needs to be flattened.
Re: 4x4 conversion
Thanks, that picture was extremely helpful! tied everything together a bit for me!
Re: 4x4 conversion
My Longhorn started life as a 2WD but conversion was done before I got it. The hardest part I think is getting the big hole in the right location for the rear spring shackle. I did cut out and rework this area during my restoration because the holes were cut-out with a torch, a little out of location, and they were around the E-Brake dimples. This made bolting the cast iron shackle bracket difficult because it needs all three (3) bolts on a flat surface.
Pictures are after reworking. |
Boosted Member
Re: 4x4 conversion
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Re: 4x4 conversion
I'm really starting to consider cannibalizing my 86 suburban for the conversion.
it's got most of the stuff I want/need for the conversion already (3/4 ton axles!) this could get very interesting...
Newbee
Re: 4x4 conversion
Do it! Lol
Re: 4x4 conversion
Re: 4x4 conversion
well guys, looks like I will be doing the swap with a 3/4 ton instead of a 1/2 ton. I'm going to be combining my two trucks to make one good 2wd 3/4 ton and then swap a front axle under it and make it 4wd later.
http://67-72chevytrucks.com/vboard/s...d.php?t=635077
#15 |
Re: 4x4 conversion
started swapping my 1/2 ton cab onto a 3/4 ton frame, that I will later convert to 4x4, details are in my build thread. and cab swap thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=594908 http://67-72chevytrucks.com/vboard/s...d.php?t=635077
