Closed Thread
Old 07-13-2014, 08:31 PM   #3601
Dan in Pasadena
Dan in Pasadena's Avatar
Re: What Did You Do With Your Truck Today ?
Originally Posted by ChuckDriver View Post
Gave my 57 a facelift!!
JJ, you know I love your truck but what are your plans? Are you turning it into a GMC step side or maybe a GMC Suburban Carrier? Those are more rare than hen's teeth as I'm sure you know.
I thought you'd posted awhile ago that you intended to make your truck into a Cameo, but now I'm a bit confused. She's still a GREAT looking truck!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline
Old 07-14-2014, 07:02 AM   #3602
47 Fasttoys
47 Fasttoys's Avatar
Dang Softpatch, I think what you really need is a few more leaf springs. What was that thing hauling, all the steel to build the Titanic?
Rob
My '47 C.O.E build
47 Fasttoys is offline
Old 07-14-2014, 04:48 PM   #3603
capnduane
capnduane's Avatar
My cab had been smelling like gasoline when I would fuel up. Large hose would leak no matter how tight the clamp was. So I ordered a set of hoses, and a new filler neck grommet, as the 60 yr old original was looking a bit tired.... Got them off the internet from Grumpys parts in Arizona. They arrived in two days! Hoses and grommet fit perfectly, just a bit of grunting, and a little lube, to get them on. 81 deg and 50% humidity here in So Cal today, actually had a tiny bit of rain!
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder"
capnduane is offline
Old 07-15-2014, 12:20 AM   #3604
mechanixman
mechanixman's Avatar
Sweet Capnduane!
I finally got my master cylinder mounted!
-Nick
Projects:
1952 Chevy 1 ton = The Build page
mechanixman is offline
Old 07-15-2014, 10:37 AM   #3605
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Dan, Just going to run the GMC for now, the Cameo conversion is a long ways off!
ChuckDriver is offline
Old 07-15-2014, 11:07 AM   #3606
topdown99
topdown99's Avatar
Looks AMAZING!
What grill/front end is that? - nevermind, I found it!
1957 3100 - 235/4spd - CPP 3" front drop axle & disc brake kit, CPP rear suspension kit, 15x7 & 15x8 Corvette rally wheels
topdown99 is offline
Old 07-15-2014, 12:39 PM   #3607
wolffcub
wolffcub's Avatar
Got the front fenders and grille on last friday.
wolffcub is offline
Old 07-17-2014, 10:53 AM   #3608
Softpatch
Softpatch's Avatar
great looking truck ....
Would like to know more about the wheels (Rim's)
like the color.! what is it (orange) your handy work..?
How did you do it Spraybomb.?
Two stage ?.
.Base-clear coat.?
.........Thanks Sp
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline
Old 07-17-2014, 11:49 AM   #3609
ChuckDriver
Two stage ?.
.Base-clear coat.?
.........Thanks Sp
Thanks Sp! I bought the rims from Stockton Wheel, 15x8 fronts and 16x10 rear, and the were powder coated orange by them too.
Old 07-17-2014, 12:06 PM   #3610
Dan in Pasadena
Thanks JJ.
Are you missing pieces to complete the Cameo conversion?
Since you're wheels are orange I'm wondering what your eventual final color scheme is planned to be? Orange two tone could look great. A little like a 50-50 bar!
Old 07-17-2014, 07:29 PM   #3611
Russell Ashley
Russell Ashley's Avatar
I like the direction this truck is going. I was looking for a truck with a six in it when I bought mine.
Russell Ashley is offline
Old 07-17-2014, 09:09 PM   #3612
Tomb23
Got My column almost done . Made new shifter Knob & Made new Handle Boot.
Tomb23 is offline
Old 07-19-2014, 01:31 PM   #3613
crossfire84
crossfire84's Avatar
My new dyna tech driveshaft came today, one step closer!
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline
Old 07-19-2014, 08:06 PM   #3614
rgunlock
rgunlock's Avatar
That is a dang nice job on the shifter knob Tomb23!
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline
Old 07-20-2014, 10:35 PM   #3615
Half Baked
Half Baked's Avatar
Started to tear apart rear brakes...a major overhaul is needed.
Cheers,
Chris
1951 Chevrolet 3100 Pick up
Half Baked is offline
Old 07-21-2014, 12:13 PM   #3616
OrrieG
OrrieG's Avatar
Welding and finish work on the step repair. Major shop cleanup after finishing woodworking honey dos.
OrrieG is offline
Old 07-21-2014, 07:36 PM   #3617
crossfire84
Scrubbed down the C4 rear end now all clean and shiny.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 07-24-2014, 02:45 PM   #3618
wolffcub
wolffcub's Avatar
Installed the seat covering, hood and finished up the front wiring over the last few days.
wolffcub is offline
Old 07-25-2014, 10:44 AM   #3619
nvrdone
Noticed an oil spot on the floor under the right rear wheel, so decided to find out what's up.
Found grease seal was leaking & wheel bearing was real noisy. When I pulled it apart, the axle out, the bearing rollers fell out of the cage and rolled down the axle tube into the diff.
So after replacing bearings, seals & brakes on both sides plus draining the diff & removing the bearing rollers, today its off to the tile store to get tile for a bathroom remodel
nvrdone is offline
Old 07-25-2014, 04:36 PM   #3620
crossfire84
Fixed the dash for the radio, put 2 fender washers in the new holes i just cut to fix the ugly that was left behind.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 07-25-2014, 11:22 PM   #3621
Dan in Pasadena
Looking at the radio photo for some reason the ground metal looked like old fashioned clear glass cabinet knobs. They're not but then I thought, "...that might be cool!"
Old 07-26-2014, 12:32 PM   #3622
nvrdone
Took my wife out for dinner last night in the truck. She enjoyed the re done interior and the quieter exhaust. Woo hoo - points for me !!!
nvrdone is offline
Old 07-26-2014, 06:03 PM   #3623
YahamaR1
YahamaR1's Avatar
Was is Bakersfield CA for this last month, orderd a lot of stuff by Summit.
4 boxes of dynamat extreme.. And a lot of little things for the lokar shifter..
Did'nt know the dynamat is so heavy.. Did not fit in my suitcase to the Netherlands.. So now its going with usps.. Hope to continue soon with my build...
YahamaR1 is offline
Old 07-26-2014, 09:34 PM   #3624
OrrieG
OrrieG's Avatar
Worked on the door edge, getting close.
OrrieG is offline
Old 07-28-2014, 11:30 PM   #3625
OrrieG
OrrieG's Avatar
Worked on the door some more. Took a break and did the paint and body work on this 1940's desk we scored at a yard sale. Cannot believe the 60 year old melamine top survived (did take an hour and a half to get the old tape off with laquer thinner).
OrrieG is offline
Closed Thread
