Old 07-26-2014, 08:50 PM   #1
dhughins
dhughins's Avatar
are there holes under side trim? 1984 c10
what will i find if i remove side trim? i think the truck was originally blue and grey. i wanna remove the trim down the sides but i guess i wont know till i take it off right? will there be holes or just sticky stuff?
dhughins is offline   Reply With Quote
Old 07-26-2014, 09:12 PM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: are there holes under side trim? 1984 c10
I think only in the rear bed corners. But not 100%
Old 07-26-2014, 10:12 PM   #3
f.monroe
f.monroe's Avatar
There are holes just in front and rear of the rear wheel opening and at the rear where the corner trim bolts on.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 07-26-2014, 10:33 PM   #4
Keith Seymore
Keith Seymore's Avatar
Frank
Negative. No holes near the wheel openings; only at the rear corner where the corner trim bolts on.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-26-2014, 11:16 PM   #5
f.monroe
f.monroe's Avatar
K
I guess maybe it could be a year model thing but on this 1983 bed it has holes for clips that keep the trim pulled in where the bed curves out at the wheel well . Every 81-87 bed I have seen has had these.
Frank
Old 07-26-2014, 11:43 PM   #6
Just call me Sean
Just call me Sean's Avatar
My '87 bed didn't.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 07-26-2014, 11:44 PM   #7
dhughins
dhughins's Avatar
Ok I will not be removing trim anytime soon now. Thanks.
Old 07-26-2014, 11:54 PM   #8
f.monroe
f.monroe's Avatar
They may have stopped using the clips by '87. Not sure but I know they did before that as evidenced by the original paint '83 bed I posted. I would look up from underneath at the backside of the panel.
Frank
Old 07-27-2014, 12:08 AM   #9
Just call me Sean
Out of curiousity I checked out my '83 and I can feel a hole but I don't feel a clip. Weird.
Old 07-27-2014, 10:30 AM   #10
Keith Seymore
Frank
Wow. I don't remember that; my '87 certainly didn't have those.
It sure would help keep the molding tight in that "cove" area, though, which was a problem spot.
K
1979-1986
1986 - 2019
Old 07-27-2014, 01:05 PM   #11
bdiamond
My 82 Blazer has holes on each side of the rear well and on the rear of the front well. My 82 pickup had the holes too.
bdiamond is offline   Reply With Quote
Old 08-04-2014, 01:49 PM   #12
Jeepwm69
My 83 has holes right behind the front wheels, and the rear corners are bolted on. The rest was just held on (poorly) with adhesive.
Mine's all peeded off over the years. Wish I could find an exact match to the trim in you pic OP. That's what my High Sierra had on it, and while there are a lot of "kinda close" trims out there, there isn't any exactly match to the black and chrome available.
Jeepwm69 is offline   Reply With Quote
Old 08-04-2014, 08:18 PM   #13
nekkidhillbilly
my 84 was all tape
nekkidhillbilly is offline   Reply With Quote
Old 08-05-2014, 07:41 AM   #14
Keith Seymore
Originally Posted by nekkidhillbilly View Post
my 84 was all tape
I'm beginning to think there was some variation between plants.
K
1979-1986
1986 - 2019
