![]() Join Date: Sep 2011
I have a 62 short bed fleet side need to install 65 bed
I have a 62 short bed fleet side truck I got a 65 bed with it how do make a 65 short fleet side bed work? Can I buy what is needed?
#2 | |
![]() Join Date: Mar 2013
Re: I have a 62 short bed fleet side need to install 65 bed
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
The bed itself is the same AFAIK, but the frames are different in '60-'62. IIRC there is some slight work needed to swap them; I don't have an x-frame truck to check, but someone else should chime in shortly.
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
It'll mount.
But the mounts on the bed will need to be moved to line up with the 62 frame.
Yeah, that's what I was thinking I remembered hearing.
Someone has the flat plates for the channels. Just need to weld them outside the others to get the bolt hole feet in right spot. Might want to replace rear member to get holes in right spot or cut and move the triangular pieces. Mar-K or Bruce Horkey or LMC has the metal pads.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
![]() Join Date: Aug 2004
only difference is the rear mounts, you will need to remove the mounts and re weld further out.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Thank you for all information will get it done now.
