Resto under way, Door Questions 63 GMC
I need help with some Door questions.
The metal work is done on my 1963 doors. Any real nice regulator set ups out there? Is a power set up the way to go or are they too much trouble? I need to buy the glass, is it all the same wherever you get it? Same as the felts anad rubbers? I saw some latches in the magazine and they advertize they shut like a new car door. Is there anything to that? I am trying to stay as close to original as function will allow, I hope to drive this truck a lot. Thanks for the help. Jay |
60-66 Nut
Re: Resto under way, Door Questions 63 GMC
I can't answer your questions, but here's a bump for you.......
![]() Join Date: Sep 2011
For window felts and rubber use Steele brand. More expensive but much better quality.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
Thanks,
Anybody got any info on regulators or power window set ups? |
You won't go wrong with Steele, I've heard they buy from Precision so you might check them out. http://precisionrestorationparts.com/ I bought my glass from a vendor, the vent glass fit and the window glass didn't. So I'd just have the glass cut by a local glass shop.
hello! I will be buying a power window set up from nu-relics in north Carolina,looks like a well made regulator and they use gm window motors.i think electric life makes a setup,but they look flimsy to me.jmo. good luck.
| Bookmarks |
| Tags |
| 1963, doors, gmc |
