Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 07-19-2014, 04:05 PM   #1
Ironhorse
Ironhorse's Avatar
Pressure Washer ??
Thinking on getting a pressure washer, mostly to keep the vinyl siding clean and maybe to clean the deck boards. Have no clue on them, how big a pressure washer would I need, PSI rating, engine horsepower rating and etc. Any brands better than others, usually are, just have no experience with them. Anyone with some tips on what to buy and what to stay away from?
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 07-19-2014, 07:38 PM   #2
Re: Pressure Washer ??
I got this one from Lowe's and it has served me well. I have run it hard the last 8 years and she still runs/works great with just regular servicing of the oil and plug. It was on Sale when I got it, but I honestly don't remember what I paid for it. I had an electric one that my wife and daughter had gotten me and it STUNK. No power and not much flow either.
Old 07-19-2014, 08:22 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
Ironhorse,
If at all possible go with the horizontal shaft engine/pump configuration like Bill posted, Also make sure what ever brand you choose the pump head is made of brass. The vertical mounted pumps are not as good, Especially if it's the all aluminum body & pump head version. They tend to corrode internally when stored blocking passages requiring a new pump.
Most all of the big box store machines use the same brand pump so do a little shop'n around and find your best deal, A 3000 psi in the homeowner line would work fine for anything you'd want to do.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 07-19-2014, 10:26 PM   #4
flashed
I use one a lot at work with a Honda engine ,been using it for years and it has never failed yet and it is a 3000 PSI . I have one at home I bought many years a go that I bought at Lowe's with a Briggs engine with less PSI and I wish I had opted for a good 3000 PSI with the Honda engine .Also when cleaning Vinyl siding Lowe's sells a deck cleaner that works great by spraying full strength in a garden sprayer ,wet the siding and then spray this stuff on and let it sit about 15 minutes . It is Olympic Premium deck cleaner ,I swear by this stuff at work.
flashed is offline   Reply With Quote
Old 07-20-2014, 06:05 AM   #5
dieseldawg142
dieseldawg142's Avatar
x2 on the honda's. my dad has 2 honda powered p.washer from the late '90's that work perfectly, 3000psi.
personally, i think 3000psi is overkill for around the house, too easy to damage things if not careful. i borrow my dad's mostly for cleaning frames & automotive stuff.
i have a 1800 psi karcher electric i bought on sale at wally world 6 or 7 yrs ago for under $100. bought it mainly to wash off our atv's (car washes dont like it when your quads have 50 lbs of mud on them), but every spring i wash all the green off the north side of the house, the sidewalks, carport, everything. takes everything off no problem, actually surprised it has lasted as long as it has. if it blew up tomorrow it would not bother me, for the price & service, i cant complain
dieseldawg142 is offline   Reply With Quote
Old 07-20-2014, 08:40 AM   #6
Restrorob
Restrorob's Avatar
While that may be true, That's why there's throttle controls on most machines. If you have a light job backing the throttle down will reduce pressure output, It's always better to purchase a little larger machine than what you think you'll need than run across a job wishing you had larger.
Also, Did you know the listed PSI rating is not what comes out of the end of the wand ?
Say a unit is rated at 3000 psi, That's the rating with the wand not depressed. Once you depress the wand you may have a actual 2300 to 2500 psi out of the wand, I can't explain why makers rate the psi like this but I see it all the time. Even my big commercial rental units have this drop in pressure......
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 07-20-2014, 11:50 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
We bought a Generac (us made, and made in WI 20 miles from where I live). We got a foam lance for it and use it to clean the cars.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-20-2014, 02:25 PM   #8
Ironhorse
Ironhorse's Avatar
Thanks for the replies, keep'em coming. Next time I get to "the big city" (aka Wichita, LOL) I will do some looking around. Not in a hurry but would like a decent one if I'm going to spend the $$
Wellington, Ks
Old 07-20-2014, 03:51 PM   #9
71swb4x4
71swb4x4's Avatar
I have a John Deere with a Honda engine. It's a 2800 psi I think. The key is to run the right tip for the job. I bought extra tips and that has helped a lot. I have used it to remove paint from my garage before painting, clean the mower, clean the deck, etc.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-20-2014, 05:39 PM   #10
cdowns
cdowns's Avatar
i have a 12 year old karcher with a honda motor 2800 lbs works great has never failed to start and pump after all these years
i bought i think either lowes or home depot bck then
cant push the honda motors any better and as far as pressure the bigger you can get the better as far as i'm concerned
Old 07-21-2014, 12:03 AM   #11
BossHogg69
motor exploder
BossHogg69's Avatar
I've also got a Troy-bilt from Lowe's, rated @ 2550 psi. I use mine for cleaning the siding on the house, cleaning the driveway, washing the cars, etc. I will say, my house is only one story and it JUST reaches the tops of the gable ends with me standing on the ground. It has been a solid little unit - I've had it for about 5 years and it was around $300 if I remember correctly.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 07-23-2014, 10:12 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
I drove a pressure washing 5 ton truck,years ago.
bigger was always better,but too much can shread things quickly.
washing right agaist the paint may leave clean streaks
or worse
a small bump/bubble of paint can rip open.
always wash a wall bottom to top,
i did a friends pool deck,(1600 home machine)wore off the leather over the steel toes(holding 1 inch off deck)
I have a small machine for at home
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 07-25-2014, 02:46 PM   #13
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
A good trick to maintain your pump=
Put some RV antifreeze though it when you are going to let it sit more than a couple of weeks. I use a funnel and a short length of garden hose. Put some of the RV antifreeze in the upheld funnel attached to the hose and pull on the starter until it forces the water out of the pump and the antifreeze is coming out of the high pressure fitting. (where you pressure line hooks to the pump.) This single maintanance technique will keep uour pump and O-rings good for years.
Tom Vogel is offline   Reply With Quote
Old 07-25-2014, 08:30 PM   #14
Ironhorse
Ironhorse's Avatar
Thanks for that tip Tom. Will keep that in mind when I do find the pressure washer I want.
Wellington, Ks
Old 07-27-2014, 05:25 PM   #15
_Ogre
_Ogre's Avatar
i borrow my neighbors
shop air compressor timer
Old 07-28-2014, 10:39 AM   #16
ERASER5
ERASER5's Avatar
What ever you get, look at the extra nozzles for sale. Find a Paint remover or spinner nozzle. This nozzle uses way less water and cleans a larger area per sweep than standard nozzles. The hole is tiny, but it spins making the over all pattern wide. I am on a well, so using 1/3 the amount of water is important to me. Plus, it is faster working.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 07-28-2014, 12:54 PM   #17
Old Truck Man
Old Truck Man's Avatar
I have one exactly like the one Palf 70 Step has pictured. Bought it for $90.00 at a estate sale. Have used it for three years and it works very well. you have to protect any washer from freezing in the winter.
Old Truck Man is offline   Reply With Quote
Old 08-06-2014, 04:55 PM   #18
truckster
truckster's Avatar
I also have a 90 degree fitting for mine. It's great for washing the undercarriage and stuff like that.
truckster is offline   Reply With Quote
Old 08-07-2014, 12:38 PM   #19
ERASER5
ERASER5's Avatar
90°? wow! I want one! How do you keep it from turning in the quick coupling?
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 08-25-2014, 04:47 PM   #20
Cash3481
Loves all GMC trucks
Cash3481's Avatar
Here is the one we use at work.
Diesel heater and a ton of pressure.
Personally,
I have 3500 PSI one from lowes too.
It works great and I use it all the time.
I bought it over Labor Day and got my military discount after the sale price!
If you ever need to get some really hot pressurized water for your truck or anything on a trailer... Go to Windfields car wash. I used it one day passing through and my gloves were burning before I was finished.
Mike
If your helping someone and expecting something in return... your doing business not kindness!
Cash3481 is offline   Reply With Quote
Old 08-25-2014, 05:43 PM   #21
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Is that a chain? I've never heard of Winfields, at least not anywhere around here...we don't even have those DIY car wash stations here much.
I did get to use an industrial pressure washer a few years back with a mechanical contracting firm. It was similar to the one pictured above, but it had a much larger 220v generator unit and was designed to spray a hot chemical solution for pulling paint and par-cured concrete off of the ground.
Old 08-25-2014, 06:16 PM   #22
Cash3481
Cash3481's Avatar
Sorry, should have clarified! Winfield is a small town near Gary with an unbelievable heated pressure washer! The degreaser mode, heat and pressure can take concrete off concrete! Lol
Mike
Old 08-25-2014, 06:57 PM   #23
slowcpe
slowcpe's Avatar
I've got a cheapie electric one. ($150). It works great for most of the around the house things. Not quite enough pressure (1900 I think) to thoroughly clean a frame and such. It suits (most) of my needs.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
