Closed Thread
Old 07-30-2014, 10:46 AM   #3626
Daze57
Daze57's Avatar
Re: What Did You Do With Your Truck Today ?
cool lookin desk
Daze57 is offline
Old 07-30-2014, 04:14 PM   #3627
Dan in Pasadena
Dan in Pasadena's Avatar
As I posted on another thread, I bought a Fatman Fabrications stage II IFS kit with a power steering rack. This is the first time I've had anything to post on this thread in a year if I'm honest.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline
Old 07-30-2014, 06:27 PM   #3628
Bone$
I Touched my LS1 sitting in my garage and dreamed of doing burnouts in my 54..
Bone$ 54 Gmc Build
Bone$ is offline
Old 08-03-2014, 09:48 PM   #3629
abrahamseven
abrahamseven's Avatar
I installed my rear left fender and put my rear bumper and brackets on
steve
abrahamseven is offline
Old 08-04-2014, 02:39 PM   #3630
iowaboynca
iowaboynca's Avatar
turned it over just to make sure the ol' 235 still runs...still debating best way to get it to the scales (trailering 1.5 miles or limping there and back) to finalize getting it registered
iowaboynca is offline
Old 08-04-2014, 03:47 PM   #3631
Hogger54
Hogger54's Avatar
Got my door weatherstrip on. Still messing with door alignment now.
Got my hood on.
Had to replace two front leaves to get the front springs off the bump stops.
Hogger54 is offline
Old 08-04-2014, 04:36 PM   #3632
lv2tri2
Very nice work.
lv2tri2 is offline
Old 08-04-2014, 05:15 PM   #3633
la hi
cut the tail pipes off and put the tank in. fits perfect and I can't wait to hear the new sound. I had four glass packs and now I have two with the 454.
la hi is offline
Old 08-04-2014, 08:53 PM   #3634
51 okie
Active Member
I scored this 235, all apart mind you. It looks to be in great shape. A little machining and put it together. Big kids model engine. All looks to be there. 2 rocker covers, clutch plate, 2 cams, one supposedly from a vette? Any ideas about that, can it work? Is it better? $50
51 okie is offline
Old 08-05-2014, 10:12 PM   #3635
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Modified the brake pedal, using a piece from a second one, so that I could install a "Power Brake" pad from a 58 sedan that I picked up at the Good Guys show in Charlotte last fall!
ChuckDriver is offline
Old 08-05-2014, 11:18 PM   #3636
oldman3
oldman3's Avatar
Sweeeeet...Jim
oldman3 is offline
Old 08-06-2014, 08:51 AM   #3637
Russell Ashley
Russell Ashley's Avatar
Nice job on the brake pedal. When I got my truck it had at some time in it's life had an automatic transmission in it, and it had a wide brake pedal from a Chrysler welded on to the brake stem. I removed it and got an original pedal from another forum member. If I should ever convert to an automatic I think I will steal your idea. I like it.
Russell Ashley is offline
Old 08-10-2014, 01:25 AM   #3638
oldcouple
oldcouple's Avatar
Had to buy a new battery, old one exactly 3 years old, and just off warranty. Then got it started and pulled it outside and washed all the fly poop and dust off it. Turned it around in the drive way and backed it in. Put new plates on for current state. Then managed to destroy the wire loom for the passenger door. So more stuff to do now.
Retired and too busy to work.
oldcouple is offline
Old 08-10-2014, 01:18 PM   #3639
OrrieG
OrrieG's Avatar
Chuck, thanks for the reminder, I need to do that too, still have the stock manual trans brake pedal.
OrrieG is offline
Old 08-10-2014, 01:40 PM   #3640
dubie
dubie's Avatar
Took it to a small car and bike show
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline
Old 08-11-2014, 10:34 AM   #3641
Dan in Pasadena
She's looking good Tim!
I finally took my truck out, gave her a thorough wash, waxed the chrome and found there was some light overspray from another project I'd been working on. I took her on a short run to my local OSH for some 0000 steel wool which cleaned it right off; they shine like new again.
I also got a bit of a wild hair and knifed off the rock-hard rear window rubber to re-install with new Softseal rubber from The Truck Shop. It turned into a PITA.
I tried taping the rubber onto the glass, then the window frame. No dice, it kept coming off so I said screw it. I'll take her to a local glass shop; I don't need the aggravation.
Also while working under the hood I finally found where the carb is leaking so I'll be pulling it off tonight to get a rebuild or a new carb on there. It's a slippery slope, gentlemen!
Old 08-13-2014, 07:30 PM   #3642
crossfire84
crossfire84's Avatar
Went to the junk yard and found a nice floor mounted parking brake handle a few days ago, Just mounted my Lokar universal parking brake lines.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline
Old 08-16-2014, 06:50 PM   #3643
Dan in Pasadena
Pulled my Holley out today and I decided to rebuild it since it seems to be sized right for my little 283.
A trip to Pep Boys for a gallon of carburetor cleaner and to Blair's Speed Shop here in Pasadena and I got a new rebuild kit.
I also decided to complete a little improvement I'd started months ago (EEK!). Stripping the coating on the lip of my old school knock-off Torq Thrusts so I can polish them. I bought a quart of epoxy paint stripper and it came off surprisingly faster than my previous (dangerous) try which was jacking up the truck while running in gear and using sandpaper!
Old 08-16-2014, 10:24 PM   #3644
Ozzy2013
Ozzy2013's Avatar
Sounds safer .ha ha
Ozzy2013 is offline
Old 08-16-2014, 10:45 PM   #3645
Dan in Pasadena
Originally Posted by Ozzy2013 View Post
Sounds safer .ha ha
Yup! I had visions of me getting hung up,on the turning wheel and getting my arm ripped off. I did one wheel that way and thought, "You're a DAMN fool for doing this!" So I stopped.
Old 08-16-2014, 11:12 PM   #3646
Ozzy2013
Ozzy2013's Avatar
Ha ha ha been there said the same thing a few times at least you stopped before you ripped an arm off .Its when we don't listen to that little voice we regret it.
Ozzy2013 is offline
Old 08-17-2014, 12:17 AM   #3647
Dan in Pasadena
Where was the little voice BEFORE I did this dumbschit thing?!
I made sure I had no sleeves and I didn't wrap the sandpaper around a finger or anything but the voice STILL said, "This is STOOPID".
Old 08-19-2014, 04:49 PM   #3648
pvienneau
pvienneau's Avatar
Removed rear spring leaf rear hanger bushings. Started with a 1/2 inch 6 inch Hex head all threaded bolt, a 22 mm socket and a couple washers to get it started out. Once you hear that snap and it starts go to a 3/8 inch 6 inch carriage bolt. I used the closed end of a 15/16 and a 1 inch wrench with the 22 mm socket to get the bushing length. I don't have long sockets. I turned them both out by hand. The hex head on the 1/2 inch bolt is 3/4 inch across points. The head on the 3/8 carriage bolt is 3/4 D.
Pat
1949 unmolested Indy Farm Deluxe AD
1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544
pvienneau is offline
Old 08-19-2014, 04:59 PM   #3649
topdown99
topdown99's Avatar
great idea and great info!!
1957 3100 - 235/4spd - CPP 3" front drop axle & disc brake kit, CPP rear suspension kit, 15x7 & 15x8 Corvette rally wheels
topdown99 is offline
Old 08-20-2014, 11:27 AM   #3650
yossarian19
Today, on a business trip with the wife.
Monday, I hung a 3/4 ton chain hoist from the rafters and pulled the bed off with it. I'll be looking at my lumber options when I get back home, & doing some metalwork on the bed at the same time.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline
Closed Thread
