Old 07-30-2014, 10:46 AM   #1
serge
serge's Avatar
tranny pan
Is it okay to put a drain plug in tranny pan?
Any recommended type of bolt for this?
Would reinforce pan for tapping threads.
serge is offline   Reply With Quote
Old 07-30-2014, 10:49 AM   #2
hugger6933
Re: tranny pan
B&M makes a great drain plug kit and I don't think it is too expensive. It also has a magnetic tip to catch the metal to pull it out of the oil. Jim
hugger6933 is offline   Reply With Quote
Old 07-30-2014, 01:05 PM   #3
nzc10
nzc10's Avatar
Re: tranny pan
With the pan off you could also get a oxygen sensor threaded fitting the bit the sensor screws into most exhaust will have these very cheap drill a hole to suit and weld in fitting iv used this method for repairing striped threads on engine sump plug holes just make sure you use a copper or nylon washer on the plug
nzc10 is offline   Reply With Quote
Old 07-30-2014, 01:24 PM   #4
Steve Cole
Re: tranny pan
My aftermarket pan for my turbo 400 came with one in it.
Steve Cole is offline   Reply With Quote
Old 07-30-2014, 04:05 PM   #5
Big Kev-O
Big Kev-O's Avatar
Re: tranny pan
I just installed one on my 700R4. I picked it up from Oriley Auto for under 10 bucks. Drop the pan, drill a hole in it, screw the new drain plug assembly together, done.No welding required. B&M and Dorman part looks identicle. Dorman part #326-65128. You should be able to pick on up at any auto parts store.
Big Kev-O is offline   Reply With Quote
Old 07-31-2014, 08:21 AM   #6
serge
serge's Avatar
Re: tranny pan
Great information. Very helpful.
Thanks guy's.
